How to Build an Intelligent B2B Lead Generation Workflow with n8n and Scrapeless
Transform your sales prospecting with an automated workflow that finds, qualifies, and enriches B2B leads using Google Search, Crawler, and Claude AI analysis. This tutorial shows you how to create a powerful lead generation system using n8n and Scrapeless.
Prerequisites
  • An n8n instance (cloud or self-hosted)
  • A Scrapeless API key (get one at scrapeless.com)
You only need to log in to the Scrapeless Dashboard and follow the picture below to get your API KEY. Scrapeless will give you a free trial quota.
  • Claude API key from Anthropic
  • Google Sheets access
  • Discord webhook URL (or your preferred notification service)
  • Basic understanding of n8n workflows
Complete Workflow Overview
Your final n8n workflow will look like this:
Step 1: Setting Up the Manual Trigger
We’ll start with a manual trigger for testing, then add scheduling later.
  1. Create a new workflow in n8n
  2. Add a Manual Trigger node as your starting point
  3. This allows you to test the workflow before automating it
Why start manual?
  • Test and debug each step
  • Verify data quality before automation
  • Adjust parameters based on initial results
Step 2: Adding Scrapeless Google Search
Now we’ll add the Scrapeless Google Search node to find target companies.
  1. Click + to add a new node after the trigger
  2. Search for Scrapeless in the node library
  3. Select Scrapeless and choose Search Google operation
1. Why Use Scrapeless with n8n?
Integrating Scrapeless with n8n lets you create advanced, resilient web scrapers without writing code.
Benefits include:
  • Access Deep SerpApi to fetch and extract Google SERP data with a single request.
  • Use Universal Scraping API to bypass restrictions and access any website.
  • Use Crawler Scrape to perform detailed scraping of individual pages.
  • Use Crawler Crawl for recursive crawling and retrieving data from all linked pages.
These features allow you to build end-to-end data flows that link Scrapeless with 350+ services supported by n8n, including Google Sheets, Airtable, Notion, Slack, and more.
2. Configuring the Google Search Node
Next, we need to configure the Scrapeless Google Search Node
Connection Setup:
  1. Create a connection with your Scrapeless API key
  2. Click “Add” and enter your credentials
Search Parameters:
Search Query: Use B2B-focused search terms:
"software companies" "enterprise clients" employees:50-200
"marketing agencies" "B2B services" "digital transformation"
"SaaS startups" "Series A" "venture backed"
"manufacturing companies" "digital solutions" ISO
Country: US (or your target market)
Language: en
Pro B2B Search Strategies:
  • Company size targeting: employees:50-200, “mid-market”
  • Funding stage: “Series A”, “venture backed”, “bootstrapped”
  • Industry specific: “fintech”, “healthtech”, “edtech”
  • Geographic: “New York”, “San Francisco”, “London”
Step 3: Processing Results with Item Lists
The Google Search returns an array of results. We need to process each company individually.
  1. Add an Item Lists node after Google Search
  2. This will split the search results into individual items
Tips : Run the Google Search Node
1. Item Lists Configuration:
  • Operation: “Split Out Items”
  • Field to Split Out: organic_results - Link
  • Include Binary Data: false
This creates a separate execution branch for each search result, allowing parallel processing.
Step 4: Adding Scrapeless Crawler
Now we’ll crawl each company website to extract detailed information.
  1. Add another Scrapeless node
  2. Select Crawl operation (not WebUnlocker)
  1. Configure for company data extraction
1. Crawler Configuration
  • Connection: Use the same Scrapeless connection
  • URL: {{ $json.link }}
  • Crawl Depth: 2 (homepage + one level deep)
  • Max Pages: 5 (limit for faster processing)
  • Include Patterns: about|contact|team|company|services
  • Exclude Patterns: blog|news|careers|privacy|terms
  • Format: markdown (easier for AI processing)
2. Why use Crawler vs Web Unlocker?
  • Crawler gets multiple pages and structured data
  • Better for B2B where contact info might be on /about or /contact pages
  • More comprehensive company information
  • Follows site structure intelligently
Step 5: Data Processing with Code Node
Before sending the crawled data to Claude AI, we need to clean and structure it properly. The Scrapeless Crawler returns data in a specific format that requires careful parsing.
  1. Add a Code node after the Scrapeless Crawler
  2. Use JavaScript to parse and clean the raw crawl data
  3. This ensures consistent data quality for AI analysis
1. Understanding Scrapeless Crawler Data Structure
The Scrapeless Crawler returns data as an array of objects, not a single object:
    "markdown": "# Company Homepage\n\nWelcome to our company...",
    "metadata": {
      "title": "Company Name - Homepage",
      "description": "Company description",
      "sourceURL": "https://company.com"
2. Code Node Configuration
console.log("=== PROCESSING SCRAPELESS CRAWLER DATA ===");
try {
  // Data arrives as an array
  const crawlerDataArray = $json;
  console.log("Data type:", typeof crawlerDataArray);
  console.log("Is array:", Array.isArray(crawlerDataArray));
  console.log("Array length:", crawlerDataArray?.length || 0);
  // Check if array is empty
  if (!Array.isArray(crawlerDataArray) || crawlerDataArray.length === 0) {
    console.log("❌ Empty or invalid crawler data");
    return {
      url: "unknown",
      company_name: "No Data",
      content: "",
      error: "Empty crawler response",
      processing_failed: true,
      skip_reason: "No data returned from crawler"
  // Take the first element from the array
  const crawlerResponse = crawlerDataArray[0];
  // Markdown content extraction
  const markdownContent = crawlerResponse?.markdown || "";
  // Metadata extraction (if available)
  const metadata = crawlerResponse?.metadata || {};
  // Basic information
  const sourceURL = metadata.sourceURL || metadata.url || extractURLFromContent(markdownContent);
  const companyName = metadata.title || metadata.ogTitle || extractCompanyFromContent(markdownContent);
  const description = metadata.description || metadata.ogDescription || "";
  console.log(`Processing: ${companyName}`);
  console.log(`URL: ${sourceURL}`);
  console.log(`Content length: ${markdownContent.length} characters`);
  // Content quality verification
  if (!markdownContent || markdownContent.length < 100) {
    return {
      url: sourceURL,
      company_name: companyName,
      content: "",
      error: "Insufficient content from crawler",
      raw_content_length: markdownContent.length,
      skip_reason: "Content too short or empty"
  // Cleaning and structuring markdown content
  let cleanedContent = cleanMarkdownContent(markdownContent);
  // Contact information extraction
  const contactInfo = extractContactInformation(cleanedContent);
  // Important business sections extraction
  const businessSections = extractBusinessSections(cleanedContent);
  // Building content for Claude AI
  const contentForAI = buildContentForAI({
    companyName,
    sourceURL,
    description,
    businessSections,
    contactInfo,
    cleanedContent
  // Content quality metrics
  const contentQuality = assessContentQuality(cleanedContent, contactInfo);
  const result = {
    url: sourceURL,
    content: contentForAI,
    processed_content_length: contentForAI.length,
    extracted_emails: contactInfo.emails,
    extracted_phones: contactInfo.phones,
    content_quality: contentQuality,
    metadata_info: {
      has_title: !!metadata.title,
      has_description: !!metadata.description,
      site_name: metadata.ogSiteName || "",
      page_title: metadata.title || ""
    processing_timestamp: new Date().toISOString(),
    processing_status: "SUCCESS"
  console.log(`✅ Successfully processed ${companyName}`);
  return result;
} catch (error) {
  console.error("❌ Error processing crawler data:", error);
  return {
    url: "unknown",
    company_name: "Processing Error",
    content: "",
    error: error.message,
// ========== UTILITY FUNCTIONS ==========
function extractURLFromContent(content) {
  // Try to extract URL from markdown content
  const urlMatch = content.match(/https?:\/\/[^\s\)]+/);
  return urlMatch ? urlMatch[0] : "unknown";
function extractCompanyFromContent(content) {
  // Try to extract company name from content
  const titleMatch = content.match(/^#\s+(.+)$/m);
  if (titleMatch) return titleMatch[1];
  // Search for emails to extract domain
  const emailMatch = content.match(/@([a-zA-Z0-9.-]+\.[a-zA-Z]{2,})/);
  if (emailMatch) {
    const domain = emailMatch[1].replace('www.', '');
    return domain.split('.')[0].charAt(0).toUpperCase() + domain.split('.')[0].slice(1);
  return "Unknown Company";
function cleanMarkdownContent(markdown) {
  return markdown
    // Remove navigation elements
    .replace(/^\[Skip to content\].*$/gmi, '')
    .replace(/^\[.*\]\(#.*\)$/gmi, '')
    // Remove markdown links but keep text
    .replace(/\[([^\]]+)\]\([^)]+\)/g, '$1')
    // Remove images and base64
    .replace(/!\[([^\]]*)\]\([^)]*\)/g, '')
    .replace(/<Base64-Image-Removed>/g, '')
    // Remove cookie/privacy mentions
    .replace(/.*?(cookie|privacy policy|terms of service).*?\n/gi, '')
    // Clean multiple spaces
    .replace(/\s+/g, ' ')
    // Remove multiple empty lines
    .replace(/\n\s*\n\s*\n/g, '\n\n')
    .trim();
function extractContactInformation(content) {
  // Regex for emails
  const emailRegex = /[a-zA-Z0-9._%+-]+@[a-zA-Z0-9.-]+\.[a-zA-Z]{2,}/g;
  // Regex for phones (with international support)
  const phoneRegex = /(?:\+\d{1,3}\s?)?\d{3}\s?\d{3}\s?\d{3,4}|\(\d{3}\)\s?\d{3}-?\d{4}/g;
  const emails = [...new Set((content.match(emailRegex) || [])
    .filter(email => !email.includes('example.com'))
    .slice(0, 3))];
  const phones = [...new Set((content.match(phoneRegex) || [])
    .filter(phone => phone.replace(/\D/g, '').length >= 9)
    .slice(0, 2))];
  return { emails, phones };
function extractBusinessSections(content) {
  const sections = {};
  // Search for important sections
  const lines = content.split('\n');
  let currentSection = '';
  let currentContent = '';
  for (let i = 0; i < lines.length; i++) {
    const line = lines[i].trim();
    // Header detection
    if (line.startsWith('#')) {
      // Save previous section
      if (currentSection && currentContent) {
        sections[currentSection] = currentContent.trim().substring(0, 500);
      // New section
      const title = line.replace(/^#+\s*/, '').toLowerCase();
      if (title.includes('about') || title.includes('service') ||
          title.includes('contact') || title.includes('company')) {
        currentSection = title.includes('about') ? 'about' :
                        title.includes('service') ? 'services' :
                        title.includes('contact') ? 'contact' : 'company';
      } else {
    } else if (currentSection && line) {
      currentContent += line + '\n';
  // Save last section
  return sections;
function buildContentForAI({ companyName, sourceURL, description, businessSections, contactInfo, cleanedContent }) {
  let aiContent = `COMPANY ANALYSIS REQUEST\n\n`;
  aiContent += `Company: ${companyName}\n`;
  aiContent += `Website: ${sourceURL}\n`;
  if (description) {
    aiContent += `Description: ${description}\n`;
  aiContent += `\nCONTACT INFORMATION:\n`;
  if (contactInfo.emails.length > 0) {
    aiContent += `Emails: ${contactInfo.emails.join(', ')}\n`;
  if (contactInfo.phones.length > 0) {
    aiContent += `Phones: ${contactInfo.phones.join(', ')}\n`;
  aiContent += `\nBUSINESS SECTIONS:\n`;
  for (const [section, content] of Object.entries(businessSections)) {
    if (content) {
      aiContent += `\n${section.toUpperCase()}:\n${content}\n`;
  // Add main content (limited)
  aiContent += `\nFULL CONTENT PREVIEW:\n`;
  aiContent += cleanedContent.substring(0, 2000);
  // Final limitation for Claude API
  return aiContent.substring(0, 6000);
function assessContentQuality(content, contactInfo) {
  const wordCount = content.split(/\s+/).length;
  return {
    word_count: wordCount,
    has_contact_info: contactInfo.emails.length > 0 || contactInfo.phones.length > 0,
    has_about_section: /about|company|who we are/gi.test(content),
    has_services_section: /services|products|solutions/gi.test(content),
    has_team_section: /team|leadership|staff/gi.test(content),
    content_richness_score: Math.min(10, Math.floor(wordCount / 50)),
    email_count: contactInfo.emails.length,
    phone_count: contactInfo.phones.length,
    estimated_quality: wordCount > 200 && contactInfo.emails.length > 0 ? "HIGH" :
                      wordCount > 100 ? "MEDIUM" : "LOW"
3. Why Add a Code Processing Step?
  • Data Structure Adaptation: Converts Scrapeless array format to Claude-friendly structure
  • Content Optimization: Extracts and prioritizes business-relevant sections
  • Contact Discovery: Automatically identifies emails and phone numbers
  • Quality Assessment: Evaluates content richness and completeness
  • Token Efficiency: Reduces content size while preserving important information
  • Error Handling: Manages failed crawls and insufficient content gracefully
  • Debugging Support: Comprehensive logging for troubleshooting
4. Expected Output Structure
After processing, each lead will have this structured format:
  "url": "https://company.com",
  "company_name": "Company Name",
  "content": "COMPANY ANALYSIS REQUEST\n\nCompany: ...",
  "raw_content_length": 50000,
  "processed_content_length": 2500,
  "extracted_emails": ["contact@company.com"],
  "extracted_phones": ["+1-555-123-4567"],
  "content_quality": {
    "word_count": 5000,
    "has_contact_info": true,
    "estimated_quality": "HIGH",
    "content_richness_score": 10
  "processing_status": "SUCCESS"
This helps verify the data format and troubleshoot any processing issues.
5. Code Node Benefits
  • Cost Savings: Smaller, cleaner content = fewer Claude API tokens
  • Better Results: Focused content improves AI analysis accuracy
  • Error Recovery: Handles empty responses and failed crawls
  • Flexibility: Easy to adjust parsing logic based on results
  • Quality Metrics: Built-in assessment of lead data completeness
Step 6: AI-Powered Lead Qualification with Claude
Use Claude AI to extract and qualify lead information from crawled content that has been processed and structured by our Code Node.
  1. Add an AI Agent node after the Code node
  1. Add an Anthropic Claude node and configure for lead analysis
  1. Configure prompts to extract structured B2B lead data
    Click on AI agent → add option → System Message and copy paste message below
System Lead Extraction Prompt:
Analyze this processed company website content and extract B2B lead information. Return ONLY valid JSON:
Company URL: {{ $json.url }}
Company Name: {{ $json.company_name }}
Processed Website Content: {{ $json.content }}
Content Quality Assessment: {{ $json.content_quality }}
Pre-extracted Contact Information:
Emails: {{ $json.extracted_emails }}
Phones: {{ $json.extracted_phones }}
Metadata Information: {{ $json.metadata_info }}
Processing Details:
Raw content length: {{ $json.raw_content_length }} characters
Processed content length: {{ $json.processed_content_length }} characters
Processing status: {{ $json.processing_status }}
Based on this structured data, extract and qualify this B2B lead. Return ONLY valid JSON:
  "company_name": "Official company name from content",
  "industry": "Primary industry/sector identified",
  "company_size": "Employee count or size category (startup/SMB/mid-market/enterprise)",
  "location": "Headquarters location or primary market",
  "contact_email": "Best general or sales email from extracted emails",
  "phone": "Primary phone number from extracted phones",
  "key_services": ["Main services/products offered based on content"],
  "target_market": "Who they serve (B2B/B2C, SMB/Enterprise, specific industries)",
  "technologies": ["Tech stack, platforms, or tools mentioned"],
  "funding_stage": "Funding stage if mentioned (seed/series A/B/C/public/private)",
  "business_model": "Revenue model (SaaS/consulting/product/marketplace)",
  "social_presence": {
    "linkedin": "LinkedIn company URL if found in content",
    "twitter": "Twitter handle if found"
  "lead_score": 8.5,
  "qualification_reasons": ["Specific reasons why this lead is qualified or not"],
  "decision_makers": ["Names and titles of key contacts found"],
  "next_actions": ["Recommended follow-up strategies based on company profile"],
  "content_insights": {
    "website_quality": "Professional/Basic/Poor based on content richness",
    "recent_activity": "Any recent news, funding, or updates mentioned",
    "competitive_positioning": "How they position vs competitors"
Enhanced Scoring Criteria (1-10):
9-10: Perfect ICP fit + complete contact info + high growth signals + professional content
7-8: Good ICP fit + some contact info + stable company + quality content
5-6: Moderate fit + limited contact info + basic content + needs research
3-4: Poor fit + minimal info + low-quality content + wrong target market
1-2: Not qualified + no contact info + processing failed + irrelevant
Scoring Factors to Consider:
Content Quality Score: {{ $json.content_quality.content_richness_score }}/10
Contact Information: {{ $json.content_quality.email_count }} emails, {{ $json.content_quality.phone_count }} phones
Content Completeness: {{ $json.content_quality.has_about_section }}, {{ $json.content_quality.has_services_section }}
Processing Success: {{ $json.processing_status }}
Content Volume: {{ $json.content_quality.word_count }} words
Instructions:
Use ONLY the pre-extracted contact information from extracted_emails and extracted_phones
Base company_name on the processed company_name field, not the raw content
Factor in the content_quality metrics when determining lead_score
If processing_status is not "SUCCESS", lower the score significantly
Use null for any missing information - do not hallucinate data
Be conservative with scoring - better to underscore than overscore
Focus on B2B relevance and ICP fit based on the structured content provided
The prompt structure makes filtering more reliable since Claude now receives consistent, structured input. This leads to more accurate lead scores and better qualification decisions in the next step of your workflow.
Step 7: Parsing Claude AI Response
Before filtering leads, we need to properly parse Claude’s JSON response which may come wrapped in markdown formatting.
  1. Add a Code node after the AI Agent (Claude)
  2. Configure to parse and clean Claude’s JSON response
1. Code Node Configuration
// Code to parse Claude AI JSON response
console.log("=== PARSING CLAUDE AI RESPONSE ===");
try {
  // Claude's response arrives in the "output" field
  const claudeOutput = $json.output || "";
  console.log("Claude output length:", claudeOutput.length);
  console.log("Claude output preview:", claudeOutput.substring(0, 200));
  // Extract JSON from Claude's markdown response
  let jsonString = claudeOutput;
  // Remove markdown backticks if present
  if (jsonString.includes('json')) {     const jsonMatch = jsonString.match(/json\s*([\s\S]*?)\s*/);     if (jsonMatch && jsonMatch[1]) {       jsonString = jsonMatch[1].trim();     }   } else if (jsonString.includes('')) {
    // Fallback for cases with only      const jsonMatch = jsonString.match(/\s*([\s\S]*?)\s*```/);
  // Additional cleaning
  jsonString = jsonString.trim();
  console.log("Extracted JSON string:", jsonString.substring(0, 300));
  // Parse the JSON
  const leadData = JSON.parse(jsonString);
  console.log("Successfully parsed lead data for:", leadData.company_name);
  console.log("Lead score:", leadData.lead_score);
  console.log("Contact email:", leadData.contact_email);
  // Validation and data cleaning
  const cleanedLead = {
    company_name: leadData.company_name || "Unknown",
    industry: leadData.industry || null,
    company_size: leadData.company_size || null,
    contact_email: leadData.contact_email || null,
    phone: leadData.phone || null,
    key_services: Array.isArray(leadData.key_services) ? leadData.key_services : [],
    target_market: leadData.target_market || null,
    technologies: Array.isArray(leadData.technologies) ? leadData.technologies : [],
    funding_stage: leadData.funding_stage || null,
    business_model: leadData.business_model || null,
    social_presence: leadData.social_presence || { linkedin: null, twitter: null },
    lead_score: typeof leadData.lead_score === 'number' ? leadData.lead_score : 0,
    qualification_reasons: Array.isArray(leadData.qualification_reasons) ? leadData.qualification_reasons : [],
    decision_makers: Array.isArray(leadData.decision_makers) ? leadData.decision_makers : [],
    next_actions: Array.isArray(leadData.next_actions) ? leadData.next_actions : [],
    content_insights: leadData.content_insights || {},
    // Meta-information for filtering
    is_qualified: leadData.lead_score >= 6 && leadData.contact_email !== null,
    has_contact_info: !!(leadData.contact_email || leadData.phone),
    claude_processing_status: "SUCCESS"
  console.log(✅ Lead processed: ${cleanedLead.company_name} (Score: ${cleanedLead.lead_score}, Qualified: ${cleanedLead.is_qualified}));
  return cleanedLead;
} catch (error) {
  console.error("❌ Error parsing Claude response:", error);
  console.error("Raw output:", $json.output);
  // Structured error response
  return {
    company_name: "Claude Parsing Error",
    industry: null,
    company_size: null,
    contact_email: null,
    phone: null,
    key_services: [],
    target_market: null,
    technologies: [],
    funding_stage: null,
    business_model: null,
    social_presence: { linkedin: null, twitter: null },
    lead_score: 0,
    qualification_reasons: [Claude parsing failed: ${error.message}],
    decision_makers: [],
    next_actions: ["Fix Claude response parsing", "Check JSON format"],
    content_insights: {},
    is_qualified: false,
    has_contact_info: false,
    claude_processing_status: "FAILED",
    parsing_error: error.message,
    raw_claude_output: $json.output || "No output received"
2. Why Add Claude Response Parsing?
  • Markdown Handling: Removes json formatting from Claude responses
  • Data Validation: Ensures all fields have proper types and defaults
  • Error Recovery: Handles JSON parsing failures gracefully
  • Filtering Preparation: Adds computed fields for easier filtering
  • Debug Support: Comprehensive logging for troubleshooting
Step 8: Lead Filtering and Quality Control
Filter leads based on qualification scores and data completeness using the parsed and validated data.
  1. Add an IF node after the Claude Response Parser
  2. Set up enhanced qualification criteria
1. New IF Node Configuration
Now that the data is properly parsed, use these conditions in the IF node:
1: Add Multiple Conditions
Condition 1:
  • Field: {{ $json.lead_score }}
  • Operator: is equal or greater than
  • Value: 6
Condition 2:
  • Field: {{ $json.claude_processing_status }}
  • Operator: is equal to
  • Value: SUCCESS
Option : Convert types where required
  • TRUE
2. Filtering Benefits
  • Quality Assurance: Only qualified leads proceed to storage
  • Cost Optimization: Prevents processing of low-quality leads
  • Data Integrity: Ensures parsed data is valid before storage
  • Debug Capability: Failed parsing is caught and logged
Step 9: Storing Leads in Google Sheets
Store qualified leads in a Google Sheets database for easy access and management.
  1. Add a Google Sheets node after the filter
  2. Configure to append new leads
    However, you can choose to manage the data as you wish.
Google Sheets Setup:
  1. Create a spreadsheet called “B2B Leads Database”
  2. Set up columns:
  • Company Name
  • Industry
  • Company Size
  • Location
  • Contact Email
  • Phone
  • Website
  • Lead Score
  • Date Added
  • Qualification Notes
  • Next Actions
For my part I choose to directly use a discord webhook
Step 9-2: Discord Notifications (Adaptable to Other Services)
Send real-time notifications for new qualified leads.
  1. Add an HTTP Request node for Discord webhook
  1. Configure Discord-specific payload format
Discord Webhook Configuration:
  • Method: POST
  • URL: Your Discord webhook URL
  • Headers: Content-Type: application/json
Discord Message Payload:
  "embeds": [
      "title": "🎯 New Qualified Lead Found!",
      "description": "**{{ $json.company_name || 'Unknown Company' }}** (Score: {{ $json.lead_score || 0 }}/10)",
      "color": 3066993,
      "fields": [
          "name": "Industry",
          "value": "{{ $json.industry || 'Not specified' }}",
          "inline": true
          "name": "Size",
          "value": "{{ $json.company_size || 'Not specified' }}",
          "inline": true
          "name": "Location",
          "value": "{{ $json.location || 'Not specified' }}",
          "inline": true
          "name": "Contact",
          "value": "{{ $json.contact_email || 'No email found' }}",
          "inline": false
          "name": "Phone",
          "value": "{{ $json.phone || 'No phone found' }}",
          "inline": false
          "name": "Services",
          "value": "{{ $json.key_services && $json.key_services.length > 0 ? $json.key_services.slice(0, 3).join(', ') : 'Not specified' }}",
          "inline": false
          "name": "Website",
          "value": "[Visit Website]({{ $node['Code2'].json.url || '#' }})",
          "inline": false
          "name": "Why Qualified",
          "value": "{{ $json.qualification_reasons && $json.qualification_reasons.length > 0 ? $json.qualification_reasons.slice(0, 2).join(' • ') : 'Standard qualification criteria met' }}",
          "inline": false
      "footer": {
        "text": "Generated by n8n Lead Generation Workflow"
      "timestamp": ""
