How to set output of If node
I have a simple IF node. The false output for the node is a copy of the input. I didn’t select this behavior it seems to be a default.
The true output for the node is empty. If the input were simply copied to the output for true, that would meet my needs.
I don’t see any discussion about the output from IF nodes in the documentation. How can I access/ set/ use output on the true branch?
More generally, how does IF node treat its outputs?
There is no error.
Input to If node:
    "output": {
      "isInvoice": "YES",
      "id": "AAMkADY3M2YxNTFkLTVjNTYtNGUyMC1iYzEyLTJlNDRiNDUyZTVmZgBGAAAAAADlhvYQib4qSomtPoqPyNNFBwDoOmRFRWNuR6_cdJelOOwOAAAAZlnoAADrFiUdN37aQ5X0pTL_mlFoAAszbNgPAAA="
false output
    "output": {
      "isInvoice": "YES",
true output
<empty>
  • I am running the latest version from the cloud
  • Database: default for the cloud
  • n8n EXECUTIONS_PROCESS default
  • Running n8n via cloud
  • Operating system: macOS, current version
Hello and welcome to the community!
You need to compare with YES, not "YES". The type of comparison chosen is the one for strings, so the node doesn’t need the value to be enclosed in quotation marks.
The wrong value is the reason that the valid looking data ends up in false branch.
The If node is designed in a way that all items that match the condition end up in true branch, the remaining will end up in false branch. You connect your next action to the true branch to process the items that match the condition.
Does the above make sense?
If this resolves your issue please mark this post as a Solution.
It does make sense and better yet, it worked! Thanks
