Hello,
I am trying to use the LangChain code node to take a text as input, split it, and return the embeddings. I wanted to get use a document loader/text splitter node to have it be easily configurable, but I eventually gave up on it and hard coded the info since I couldn’t figure out how to use them from the code.
Now however I want to use the embeddings node. I have searched the docs and I can’t understand how to use the connected embeddings node. Even trying to output Object.jeys(the_node) ended up giving me no good answers as to a possible API the node exposed.
Given that I have chunks of text available, how embed them using the embeddings node? And possibly, as a step 2, how could I chunk it using a child textsplitter node as well or, better yet, use a child document loader node?
- n8n version: 1.86.0
- Database: PostgreSQL
- n8n EXECUTIONS_PROCESS setting: Don’t know, probably the defaults
- Running n8n via: Docker
- Operating system: Linux probably
