I have a problem connecting to the TheHive API
I have a problem connecting to the TheHive API. I don’t understand how exactly I should fill in “YOUR_TOKEN_HERE”. I have an Access Key ID and a Secret Key, but I’m not sure if this is the same token. And if it is, how should I enter it correctly? Right now, I’m getting errors.
I’m just learning how to work with n8n, so yeah, I probably got stuck at the easiest step…
Hi @Free,
According to TheHive docs:
Your Secret Key is your API Key
Is this correct?
