IF node wrong output
Hi n8n community.
I am encountering a bug where Switch and If nodes are making subsequent nodes run, even if no data is being pushed into it.
Here is an example:
Here you can see that the switch node is supposed to check the Subscription Type from the HubSpot Trigger node.
As you can see the Switch node is picking up on the variable, however is not following the execution rules and sending it to output 0, and not outputting to 2 as it should:
I haven’t found any answers to a similar problem on the forum, hope you guys can help!
Thanks,
Maxim
Can you share the expression you have in value 1? Or better the whole workflow?
Sure Ricardo, here is the part of the workflow that is causing me problems. It’s a pretty big workflow, so I’m only sharing part of it, the rest is symmetrical.
  "nodes": [
      "parameters": {
        "functionCode": "creation = false;\nindex = 0;\n\nfor (i=0 ; i < items.length ; i++) {\n  if ($item(i).$node[\"Set_Contact\"].data[\"subscriptionType\"] === \"contact.creation\") {\n    creation = true;\n    index = i;\n  }\n}\n\n\nif (creation == true) {\n  return [items[index]];\n}\nelse {\n  return items;\n}\n\n\n"
      "name": "Function_Contact",
      "typeVersion": 1,
      "position": [
        1000,
        980
      "parameters": {
        "functionCode": "results = [];\n\nkeyProperties = [\n    'firstname',\n    'lastname',\n    'email',\n    'a_b_quiz_score',\n    'additional_information',\n    'admin___beginner',\n    'num_associated_deals',\n    'hs_analytics_average_page_views',\n    'hs_lifecyclestage_customer_date',\n    'hs_lifecyclestage_lead_date',\n    'hs_lifecyclestage_marketingqualifiedlead_date',\n    'hs_lifecyclestage_salesqualifiedlead_date',\n    'hs_lifecyclestage_subscriber_date',\n    'hs_lifecyclestage_evangelist_date',\n    'hs_lifecyclestage_opportunity_date',\n    'hs_lifecyclestage_othelr_date',\n    'hs_buying_role',\n    'engagements_last_meeting_booked_campaign',\n    'city',\n    'closedate',\n    'code_naf',\n    'company',\n    'company_size',\n    'contact_creation_date',\n    'hubspot_owner_id',\n    'hs_predictivescoringtier',\n    'hs_is_unworked',\n    'country',\n    'criticity',\n    'chargebeecustomerid',\n    'engagements_last_meeting_booked',\n    'days_to_close',\n    'degree',\n    'e_b_quiz_score',\n    'hs_email_domain',\n    'hs_email_hard_bounce_reason_enum',\n    'annualrevenue',\n    'expert_beginner',\n    'hs_facebook_click_id',\n    'first_conversion_event_name',\n    'first_deal_created_date',\n    'hs_analytics_first_url',\n    'hs_analytics_first_referrer',\n    'hs_analytics_first_touch_converting_campaign',\n    'gender',\n    'geography',\n    'hs_google_click_id',\n    'hubspotscore',\n    'industry_radio_select',\n    'job_function',\n    'jobtitle',\n    'hs_analytics_last_referrer',\n    'hs_lead_status',\n    'lifecyclestage',\n    'hs_predictivecontactscore_v2',\n    'linkedin_url',\n    'hs_email_click',\n    'hs_email_delivered',\n    'hs_email_open',\n    'hs_email_replied',\n    'marketing_status',\n    'engagements_last_meeting_booked_medium',\n    'mobilephone',\n    'naf2_code',\n    'new_functions',\n    'numemployees',\n    'hs_analytics_num_event_completions',\n    'num_conversion_events',\n    'hs_analytics_num_page_views',\n    'num_notes',\n    'hs_analytics_num_visits',\n    'num_contacted_notes',\n    'num_unique_conversion_events',\n    'quiz_score',\n    'hs_createdate',\n    'onboarding_complete',\n    'onboarding_day',\n    'onboarding_satisfaction',\n    'one_on_one_viibe_demo',\n    'operator_beginner',\n    'hs_analytics_source',\n    'hs_analytics_source_data_1',\n    'hs_analytics_source_data_2',\n    'pain_points',\n    'phone',\n    'zip',\n    'hs_language',\n    'questions_comments_feedback',\n    'hs_sales_email_last_clicked',\n    'hs_sales_email_last_opened',\n    'hs_sales_email_last_replied',\n    'salesnavigator_url',\n    'hs_email_sends_since_last_engagement',\n    'seniority',\n    'siret_number',\n    'sizing',\n    'engagements_last_meeting_booked_source',\n    'state',\n    'address',\n    'temporality',\n    'hs_analytics_first_timestamp',\n    'hs_analytics_last_timestamp',\n    'hs_analytics_last_visit_timestamp',\n    'cb_customermrr',\n    'cb_totaldues',\n    'hs_email_optout',\n    'use_case',\n    'use_cases',\n    'va_registration',\n    'va_registration_date',\n    'viibe_csm'];\n\n\nfor (i=0 ; i < items.length ; i++) {\n  temp = { json : {}}    \n  for (j=0 ; j < keyProperties.length ; j++) {\n    if (keyProperties[j] in items[i].json[\"properties\"]) {\n      key = keyProperties[j];\n      temp.json[key] = String(items[i].json[\"properties\"][key][\"value\"]);\n    }\n    temp.json[\"hs_object_id\"] = items[i].json[\"properties\"][\"hs_object_id\"][\"value\"];\n    //temp.json[\"trigger\"] = \"creation\";\n    //temp.json[\"timestamp\"] = items[i].json[\"timestamp\"] + i;\n  }\n  results.push(temp);\n}\n\nreturn results;"
      "name": "Create_Contact",
      "typeVersion": 1,
      "position": [
        2000,
        870
      "parameters": {
        "keepOnlySet": true,
        "values": {
          "string": [
              "name": "hs_object_id",
              "value": "={{$node[\"HS_Contact_Creation Trigger\"].json[\"contactId\"]}}"
              "name": "trigger",
              "value": "deletion"
              "name": "timestamp",
              "value": "={{$node[\"Set_Contact\"].json[\"timestamp\"]}}"
          "number": []
        "options": {}
      "name": "Set_Contact_Deletion",
      "type": "n8n-nodes-base.set",
      "typeVersion": 1,
      "position": [
        1800,
        1110
      "parameters": {
        "functionCode": "results = [];\n\nkeyProperties = [\n    'firstname',\n    'lastname',\n    'email',\n    'a_b_quiz_score',\n    'additional_information',\n    'admin___beginner',\n    'num_associated_deals',\n    'hs_analytics_average_page_views',\n    'hs_lifecyclestage_customer_date',\n    'hs_lifecyclestage_lead_date',\n    'hs_lifecyclestage_marketingqualifiedlead_date',\n    'hs_lifecyclestage_salesqualifiedlead_date',\n    'hs_lifecyclestage_subscriber_date',\n    'hs_lifecyclestage_evangelist_date',\n    'hs_lifecyclestage_opportunity_date',\n    'hs_lifecyclestage_other_date',\n    'hs_buying_role',\n    'engagements_last_meeting_booked_campaign',\n    'city',\n    'closedate',\n    'code_naf',\n    'company',\n    'company_size',\n    'contact_creation_date',\n    'hubspot_owner_id',\n    'hs_predictivescoringtier',\n    'hs_is_unworked',\n    'country',\n    'criticity',\n    'chargebeecustomerid',\n    'engagements_last_meeting_booked',\n    'days_to_close',\n    'degree',\n    'e_b_quiz_score',\n    'hs_email_domain',\n    'hs_email_hard_bounce_reason_enum',\n    'annualrevenue',\n    'expert_beginner',\n    'hs_facebook_click_id',\n    'first_conversion_event_name',\n    'first_deal_created_date',\n    'hs_analytics_first_url',\n    'hs_analytics_first_referrer',\n    'hs_analytics_first_touch_converting_campaign',\n    'gender',\n    'geography',\n    'hs_google_click_id',\n    'hubspotscore',\n    'industry_radio_select',\n    'job_function',\n    'jobtitle',\n    'hs_analytics_last_referrer',\n    'hs_lead_status',\n    'lifecyclestage',\n    'hs_predictivecontactscore_v2',\n    'linkedin_url',\n    'hs_email_click',\n    'hs_email_delivered',\n    'hs_email_open',\n    'hs_email_replied',\n    'marketing_status',\n    'engagements_last_meeting_booked_medium',\n    'mobilephone',\n    'naf2_code',\n    'new_functions',\n    'numemployees',\n    'hs_analytics_num_event_completions',\n    'num_conversion_events',\n    'hs_analytics_num_page_views',\n    'num_notes',\n    'hs_analytics_num_visits',\n    'num_contacted_notes',\n    'num_unique_conversion_events',\n    'quiz_score',\n    'hs_createdate',\n    'onboarding_complete',\n    'onboarding_day',\n    'onboarding_satisfaction',\n    'one_on_one_viibe_demo',\n    'operator_beginner',\n    'hs_analytics_source',\n    'hs_analytics_source_data_1',\n    'hs_analytics_source_data_2',\n    'pain_points',\n    'phone',\n    'zip',\n    'hs_language',\n    'questions_comments_feedback',\n    'hs_sales_email_last_clicked',\n    'hs_sales_email_last_opened',\n    'hs_sales_email_last_replied',\n    'salesnavigator_url',\n    'hs_email_sends_since_last_engagement',\n    'seniority',\n    'siret_number',\n    'sizing',\n    'engagements_last_meeting_booked_source',\n    'state',\n    'address',\n    'temporality',\n    'hs_analytics_first_timestamp',\n    'hs_analytics_last_timestamp',\n    'hs_analytics_last_visit_timestamp',\n    'cb_customermrr',\n    'cb_totaldues',\n    'hs_email_optout',\n    'use_case',\n    'use_cases',\n    'va_registration',\n    'va_registration_date',\n    'viibe_csm'\n    ];\n\n\nfor (i=0 ; i < items.length ; i++) {\n  temp = { json : {}}    \n  for (j=0 ; j < keyProperties.length ; j++) {\n    if (keyProperties[j] in items[i].json[\"properties\"]) {\n      key = keyProperties[j];\n      temp.json[key] = String(items[i].json[\"properties\"][key][\"value\"]);\n    }\n    temp.json[\"hs_object_id\"] = items[i].json[\"properties\"][\"hs_object_id\"][\"value\"];\n    //temp.json[\"trigger\"] = items[i].json[\"trigger\"];\n    //temp.json[\"timestamp\"] = items[i].json[\"timestamp\"] + i;\n  }\n  results.push(temp);\n}\n\nreturn results;"
      "name": "Update_Contact",
      "typeVersion": 1,
      "position": [
        1770,
        1370
      "parameters": {
        "resource": "contact",
        "operation": "get",
        "contactId": "={{$json[\"contactId\"]}}",
        "additionalFields": {}
      "name": "HS_Contact_Update",
      "type": "n8n-nodes-base.hubspot",
      "typeVersion": 1,
      "position": [
        1550,
        1370
      "executeOnce": false,
      "credentials": {
        "hubspotApi": "HubSpot"
      "parameters": {
        "values": {
          "string": [
              "value": "={{$json[\"occurredAt\"]}}"
              "name": "trigger",
              "value": "={{$json[\"propertyName\"]}}"
        "options": {}
      "name": "Set_Contact",
      "typeVersion": 1,
      "position": [
        850,
        980
      "parameters": {
        "conditions": {
          "string": [
              "value1": "={{$json[\"subscriptionType\"]}}",
              "operation": "contains",
              "value2": "deal"
      "name": "IF",
      "type": "n8n-nodes-base.if",
      "typeVersion": 1,
      "position": [
        550,
        970
      "parameters": {
        "mode": "mergeByKey",
        "propertyName1": "contactId",
        "propertyName2": "hs_object_id",
        "overwrite": "blank"
      "name": "Merge_Contact_Update",
      "type": "n8n-nodes-base.merge",
      "typeVersion": 1,
      "position": [
        1990,
        1350
      "parameters": {
        "propertyName1": "vid",
        "propertyName2": "contactId",
      "name": "Merge_Contact_Creation",
      "typeVersion": 1,
      "position": [
        1800,
        870
      "parameters": {
        "eventsUi": {
          "eventValues": [
              "name": "deal.creation"
              "name": "deal.deletion"
              "name": "deal.propertyChange",
              "property": "dealname"
              "property": "dealstage"
              "property": "dealtype"
              "property": "amount"
              "property": "hubspot_owner_id"
              "property": "=deal_sdr"
              "property": "=deal_ae"
              "property": "=deal_kam"
              "property": "num_associated_contacts"
              "property": "num_contacted_notes"
              "property": "num_notes"
              "property": "=industry"
              "property": "=deal_source"
              "property": "=lead_source"
              "property": "=lead_medium"
              "property": "createdate"
              "property": "closedate"
              "property": "=contract_close_date"
              "property": "=pilot_close_date"
              "property": "=pilot_duration"
              "property": "=potential_internal_guests"
              "property": "=potential_premium_users"
              "name": "contact.deletion"
              "name": "contact.propertyChange",
              "property": "firstname"
              "property": "lastname"
              "property": "email"
              "property": "=a_b_quiz_score"
              "property": "=admin___beginner"
              "property": "annualrevenue"
              "property": "num_associated_deals"
              "property": "hs_analytics_average_page_views"
              "property": "hs_lifecyclestage_customer_date"
              "property": "hs_lifecyclestage_lead_date"
              "property": "hs_lifecyclestage_marketingqualifiedlead_date"
              "property": "hs_lifecyclestage_salesqualifiedlead_date"
              "property": "hs_lifecyclestage_subscriber_date"
              "property": "hs_lifecyclestage_evangelist_date"
              "property": "hs_lifecyclestage_opportunity_date"
              "property": "hs_lifecyclestage_other_date"
              "property": "hs_buying_role"
              "property": "engagements_last_meeting_booked_campaign"
              "property": "city"
              "property": "company"
              "property": "=company_size"
              "property": "hs_is_unworked"
              "property": "country"
              "property": "=criticity"
              "property": "=chargebeecustomerid"
              "property": "days_to_close"
              "property": "degree"
              "property": "=e_b_quiz_score"
              "property": "hs_email_domain"
              "property": "=hs_email_hard_bounce_reason_enum"
              "property": "=expert_beginner"
              "property": "hs_facebook_click_id"
              "property": "first_conversion_event_name"
              "property": "first_deal_created_date"
              "property": "hs_analytics_first_url"
              "property": "hs_analytics_first_referrer"
              "property": "hs_analytics_first_touch_converting_campaign"
              "property": "gender"
              "property": "=geography"
              "property": "hs_google_click_id"
              "property": "hubspotscore"
              "property": "=industry_radio_select"
              "property": "=job_function"
              "property": "=jobtitle"
              "property": "=hs_analytics_last_referrer"
              "property": "=hs_lead_status"
              "property": "=lifecyclestage"
              "property": "=linkedin_url"
              "property": "hs_email_click"
              "property": "hs_email_open"
              "property": "hs_email_delivered"
              "property": "hs_email_replied"
              "property": "=marketing_status"
              "property": "engagements_last_meeting_booked_medium"
              "property": "mobilephone"
              "property": "=naf2_code"
              "property": "hs_analytics_num_event_completions"
              "property": "=num_conversion_events"
              "property": "=hs_analytics_num_page_views"
              "property": "=num_notes"
              "property": "=hs_analytics_num_visits"
              "property": "=num_contacted_notes"
              "property": "=num_unique_conversion_events"
              "property": "=quiz_score"
              "property": "=hs_createdate"
              "property": "=onboarding_complete"
              "property": "=onboarding_satisfaction"
              "property": "=operator_beginner"
              "property": "=phone"
              "property": "=zip"
              "property": "=hs_language"
              "property": "=hs_sales_email_last_clicked"
              "property": "=hs_sales_email_last_opened"
              "property": "=hs_sales_email_last_replied"
              "property": "=salesnavigator_url"
              "property": "=hs_email_sends_since_last_engagement"
              "property": "=seniority"
              "property": "=siret_number"
              "property": "=engagements_last_meeting_booked_source"
              "property": "=state"
              "property": "=address"
              "property": "=viibe_csm"
      "name": "Hubspot Trigger",
      "type": "n8n-nodes-base.hubspotTrigger",
      "typeVersion": 1,
      "position": [
        360,
        970
      "webhookId": "98351bb4-06cf-436c-a1c6-48871691639c",
      "credentials": {
        "hubspotDeveloperApi": "HubSpot Developer API"
      "parameters": {
        "dataType": "string",
        "value1": "={{$node[\"Set_Contact\"].json[\"subscriptionType\"]}}",
        "rules": {
          "rules": [
              "value2": "contact.creation"
              "value2": "contact.deletion",
              "output": 1
        "fallbackOutput": 2
      "name": "Switch_Contact",
      "type": "n8n-nodes-base.switch",
      "typeVersion": 1,
      "position": [
        1210,
        980
      "parameters": {
        "operation": "get",
      "name": "HS_Contact_Creation",
      "typeVersion": 1,
      "position": [
        1460,
        820
      "credentials": {
  "connections": {
    "Function_Contact": {
      "main": [
            "node": "Switch_Contact",
            "type": "main",
            "index": 0
    "Update_Contact": {
      "main": [
            "node": "Merge_Contact_Update",
            "type": "main",
            "index": 1
    "HS_Contact_Update": {
      "main": [
            "node": "Update_Contact",
            "type": "main",
            "index": 0
    "Set_Contact": {
      "main": [
            "node": "Function_Contact",
            "type": "main",
            "index": 0
    "IF": {
      "main": [
        null,
            "node": "Set_Contact",
            "type": "main",
            "index": 0
    "Merge_Contact_Creation": {
      "main": [
            "node": "Create_Contact",
            "type": "main",
            "index": 0
    "Hubspot Trigger": {
      "main": [
            "node": "IF",
            "type": "main",
            "index": 0
    "Switch_Contact": {
      "main": [
            "node": "Merge_Contact_Creation",
            "type": "main",
            "index": 1
            "node": "HS_Contact_Creation",
            "type": "main",
            "index": 0
            "node": "Set_Contact_Deletion",
            "type": "main",
            "index": 0
            "node": "HS_Contact_Update",
            "type": "main",
            "index": 0
            "type": "main",
            "index": 0
    "HS_Contact_Creation": {
      "main": [
            "type": "main",
            "index": 0
Not the easiest to test because it’s based on a trigger, sorry.
Thanks!
Sorry the copy-paste didn’t work as expected, the part of the workflow that we’re looking is actually attached to the false exit of the IF node.
Yes, I can confirm. That is a bug. We will check it out.
A temporary workaround would be to connect a “NoOp” node to Output 0 and then connect the Hubspot & Merge node to that one. It will then work fine.
Apart from that, does it look like that the worklfow would not run successfully also with fix.
In the first IF-Node you directly check if “subscriptionType” contains the word “deal”. Only then it can go on. In the “Switch_Contact” node you then check if “subscriptionType” is “contact.creation” or “contact.deletion”. None of both contains the word “deal” and so it would never reach the “Switch_Contact” node. Meaning it would currently never have any data on output 0 or 1.
Good to know I’m not going crazy!
Yes I am aware, this is due to a bug when copy-pasting, I only copied the output from False in the first IF node but it shows up connected to True. This branch is only for contacts :slight_smile:
Ah OK, then this makes sense :wink:
We will inform you once the bug got fixed so that you can remove the NoOp-Node again.
Issue got fixed and will be released with the new version tomorrow:
https://github.com/n8n-io/n8n/commit/b47f4bc012b9379b3ea21725101c03daf222b87c
@jan You guys are amazing, thanks!
Got released with n8n@0.119.0
Have fun!
