Hello community,
it would be great if there would be the possibility to delete also emails at the IMAP node.
Greetings Fabian
Hello community,
Greetings Fabian
Make sure you upvote the feature request.
Yes, it would be really nice to be able to delete mail processed by the āIMAP Emailā node instead of just marking them as read.
Moving mails to another folder would be nice to. The underlying node-imap lib supports I think.
Does anyone know a workaround for as long as this feature doesnāt exist in n8n?
I created an n8n community node, n8n-nodes-imap
, which is now available for use. Hereās a snapshot of what you can expect from this node:
Mailbox Operations:
Email Operations:
I encourage you to test this node and share your experiences or suggestions.
Github repo: GitHub - umanamente/n8n-nodes-imap
Thatās a great workaround for now, thank you! Hopefully the team will some day revamp the IMAP node to natively include this as well.
i still need to delete mails (older than 10 days) from a mailbox as it is full otherwise. I get notifications there all the time that I parse but manually deleting thousands of mails is ā¦well not really great.
please enable dele mails.
You can use the āmove emailā command to move emails to the trash.
Thx for the node. I am only struggeling with setting the credentials. I the docs it says that I can reuse the credentials from the n8n IMAP trigger node. I am using this node and have created credentials successfully - but in the dropdown of your community node these credential settings do not appear. Any idea?
Whatās the version of the node?
It is the latest v2.0.1
n8n is at v1 49.0
Running on docker behind an nginx proxy
When I restart the docker container the nide still seems to be installed (listed under User Settings / Community Nodes) but when trying to add it to a workflow it does not appear anymore - strange.
Solved the problem after I found the following: Community Nodes not accessable
Deleted Browser cache - all good now
Hi very cool. I am using the hosted plan and canāt use this custom node.
Make.com offers an Imap node with this features. I am really missing this for my Email Agent⦠So any chance to get a workaround for this in the cloud version of n8n?
