Import Credentials via CLI - Problem
On latest version i export the credentials via CLI (decrypted or not) and when i try to import them it throws an error:
n8n export:credentials --backup --output=/tmp/
n8n import:credentials --input=/tmp/s7jJK8DRSKZnPaDs.json
File does not seem to contain credentials. Make sure the credentials are contained in an array.
I check the .json file and is valid as JSON file.
Any ideas?
Import all the separated files created by --backup:
n8n import:credentials --separate --input=/tmp/
Or if you exported wrong(single /separated) redo the process and re-export into a single array file :
n8n export:credentials --all –output=/tmp/credentials.json
n8n import:credentials –input=/tmp/credentials.json
