Import workflows from images using mcp-n8n + Cursor
Import workflow from image_optimized
What it does:
Import n8n workflows directly from screenshots/images into your instance using Cursor and mcp-n8n
  • Import workflows from documentation
  • Backup/restore workflow screenshots
  • Cross-instance workflow migration
Features:
  • Automatic node type detection
  • Connection mapping
  • Position preservation
  • Direct API integration
GitHub: [link]
npm: [Link]
About MCP [Link]
Hello can tou help me to understand the usefulness of MCP compared to an agent: time savings
