Installed thru NPX. Init Problem There was a problem loading init data: Unauthorized
I just install n8n on my Mac with npx command. After logging in, I found the error as I mentioned in the subject.
I’m trying to use npm method but can’t do so because of sqlite ownership of previously installed npx.
Can’t find similar problem in this forum.
hello @jmozzart
Actually the most stable and easy way is to use docker
Yes. I tried but same error. I just found out that the error lies with Safari. I switched Chrome and it worked.
