I am having an issue when trying to create a child row in NocoDB using the NocoDB node. The NocoDB documentation (here) mentions that a child row can be created by POSTing to /api/v1/tableName/:parentId/childTableName
, so I created a pattern that matches this in the “table” field of the node (tableName/:parentId/childTableName
). The resulting table name I see is indeed correct, but when the actual request is made to NocoDB, /bulk
gets automatically appended to the URL, causing the request to fail with Cannot POST to /api/v1/[...]/bulk
. I have not figured out a way of preventing this. If I only use the child table name, without its parent and parent ID, the request is working properly.
Could that be a bug?
Please share the workflow
"property-count": "44"
"property-count": "108"
"property-count": "33"
"property-count": "12"
- n8n version: 0.169.0
- Database you’re using (default: SQLite): (have not changed defaults)
- Running n8n with the execution process [own(default), main]: (have not changed defaults)
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: docker with docker-compose
