Langfuse community node integration issue
I am integrating Langfuse’s “Get Prompt” functionality with an n8n workflow. Both Langfuse and n8n are self-hosted within the same environment and securely hosted via HTTPS. However, when I input the Langfuse credentials into the community node credentials in n8n, the connection fails with the error message: “Couldn’t connect with these settings.”
Interestingly, when I connect to the HTTP (non-secure) version of Langfuse, the connection is successful without any issues. I have verified that the public and secret keys are accurate and valid in both HTTPS and HTTP cases.
Couldn’t connect with these settings” when saving credentials in Langfuse community node.
