License Activation Problem
Describe the problem/error/question:
I am unable to activate n8n license. I used my email to received activation key but entering it gives me the following message.
Activation failed
Activation key has already been used on this instance
  • n8n version: 1.114.0
  • Running n8n via (Docker, npm, n8n cloud, desktop app): npx
  • Operating system: Windows
Hi @Usman_Rasheed_Siddiq,
Are you using Hosted n8n or on-premise?
Thank you
Hi @Joao_Paixao
I am using on-premise.
Thank You
My recommendation is to uninstall and install back the n8n on-premise.
Please also restart the computer after uninstalling.
Let me know if this worked.
João Paixão
hi @Joao_Paixao ,
Thank you so much.
I cleared everything and ran it again. It asked me again for an activation key, sent an email and now it’s working properly.
The email said that the activation key can work within 14 days but I think i should have done it the very moment when I first install n8n.
I’m glad it worked.
Please mark my answer and the solution for your issue.
Thank you!
