Localhost (http://localhost:5678/) error when using e.g. Slack or Gmail "Send and wait. for response" nodes
Title: Localhost error (http://localhost:5678/) when using e.g. Slack or Gmail “Send and wait for response” nodes
n8n Version: 1.12.4
Instance Type: Self-hosted (Docker with Hostinger)
Problem:
Gmail “Send Message and Wait for Response” node generates approval links pointing to http://localhost:5678 instead of my configured domain, causing “connection refused” errors when recipients click the links.
Environment Variables in docker-compose.yml:
yaml
- N8N_HOST=${SUBDOMAIN}.${DOMAIN_NAME}
- N8N_PROTOCOL=https
- WEBHOOK_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
- N8N_EDITOR_BASE_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
- N8N_PROXY_HOPS=1
Verified inside container via:
bash
docker exec <container_name> printenv | grep -E "N8N_HOST|WEBHOOK_URL|N8N_PROTOCOL|EDITOR|PROXY"
Output confirms variables resolve correctly to subdomain.mydomain.com
What works:
  • Regular Webhook nodes show correct URL (both Test and Production)
  • Accessing n8n via subdomain.mydomain.com works fine
What doesn’t work:
  • e.g. Gmail “Send and Wait for Response” approval links still use localhost:5678
Setup:
  • Docker Compose
  • PostgreSQL database
  • Redis queue mode
Already tried:
  • Cleared browser cache
  • Created new webhook nodes
  • Restarted containers multiple times
  • Restarted VPS
  • Added N8N_PROXY_HOPS=1
Any help appreciated!!! Unfortunately this issue has not been solved also it was mentioned couple of times in the forum here in older threads.
Check if you added the correct redirect URI for your credentials in Google Console(for Gmail).
The redirect URI is usually as follows:
https://your-full-address-here/rest/oauth2-credential/callback
You also have to confirm using the same way for Slack Developer Platform.
Yes, added it in Google Cloud.
Reconnected Google Tools in n8n and still receive the error….
Solution found!
The issue was the queue mode of the n8n instance. It finally works after being downgraded via Hostinger!
Hope this helps other people.
