My fields are not being mapped correctly
I’m having trouble mapping fields correctly in my n8n workflow. My workflow retrieves data from a Google Sheet, processes it using multiple AI agents, and then writes the manipulated data to another Google Sheet.
The issue arises when trying to map the BRANCH variable to a field in the final Google Sheet module. When I drag the BRANCH variable into the target field, I either get undefined or an invalid syntax error.
Previously, I encountered a similar issue when mapping data from the first module to a Google Sheet, but I resolved it using .first(). However, .first() and $('module name') are not working in this case.
The error message:
undefinedinvalid syntax
My workflow
- n8n version: 1.77
