I’m getting a ETIMEDOUT error when connecting MySQL to the SQL AI Agent. I use SSH for the secure connection. The connection works fine with MySQL nodes, but just doesn’t work with the SQL AI Agent. I’ve tried increase the timeout limit, but not luck in mudville. Has anyone else had this problem, or know what the fix is for something like this?
n8n version
1.75.3 (Cloud)
Stack trace
Error: connect ETIMEDOUT at PoolConnection._handleTimeoutError (/usr/local/lib/node_modules/n8n/node_modules/mysql2/lib/connection.js:205:17) at listOnTimeout (node:internal/timers:581:17) at processTimers (node:internal/timers:519:7)
- 1.75.3 (Cloud)
- **Database: MySQL
- *Running n8n via: Cloud
- **Operating system: Windows
