Hello everyone, I am having a really weird issue using n8n and Jira services.
I’ve made a workflow that need to sync issue in jira.
I am experiencing a really weird issue when I turn on/off the workflow from n8n, and in the while in Jira side the webhook that i’ve create for this will show/hide based on the workflow active status
Do you have ever see something similar?
Hi @Gabriele_Bracciali, this is expected and not specific to Jira. Most n8n trigger nodes will register a webhook with the services they receive data from when they are activated and remove the webhook again when they are de-activated.
The same would happen if you manually execute such a node: A new webhook (with -test in the URL) would be registered during the manual execution and removed again once done.
