I have used n8n local deployment on my ec2 using the n8n docker image, i have setup the nginx as reverse proxy on a n8n network, I have also specified the N8N_BASE_URL as the public domain even in production it is correctly coming, but for some reason on n8n webhook url it shows localhost:5678 i have checked the nginx.conf and the docker-compose.yml as well everything seems to work as intended. Due to this reason my webhook is not getting verified on meta.
Could anyone provide a solution to this?
- n8n version:
- Database (default: SQLite):
- Operating system:
Hey @Sankalp_Sharma,
Welcome to the community
You need to set WEBHOOK_URL
to set the production webhook URL.
Don’t forget to also set N8N_PROXY_HOPS
to 1
if you are using 1 reverse proxy.
Thanks it worked!!
