We are facing an issue with workflow activation behavior in n8n after deployment. Once a workflow is deployed, it appears as active by default, but it does not get triggered as expected.
To make the workflow functional, we are required to open the workflow, perform a minor change (even a no-op edit), and save it again. Only after this manual re-save does the workflow start triggering correctly.
This behavior is consistent across deployments and affects multiple workflows, creating additional manual overhead and risk of missed executions.
Problem Statement:
Workflows are marked as active after deployment but do not trigger automatically.
Manual intervention (minor edit + save) is required to activate proper triggering.
Issue occurs consistently for every deployment.
This impacts automation reliability and requires unnecessary manual steps.
