Need help setting up viral video automation pipeline, please!
Hello, I’ve found a few templates that almost do what I need, but I’m looking to build a full pipeline that researches viral competitor videos, takes the script and re-writes it, takes the video and re-purposes it, has human-in-the-loop approval, then auto-publishes to social media channels like YouTube, Meta, TikTok, etc.
Thank you so much for your help!!
Thank you! I’m currently using getshadowscript.com to copy a YouTube URL into that app, then it analyzes it and re-writes the script, creates hooks, CTA, description, etc.
It would be great if Perplexity could do some research on the top outlier videos, copy the URL’s into a Google Sheets for like 60 videos to post 2 videos a day, then copy the YT URL into ShadowScript to have it re-written and have all the other info, then use some AI Video Generator to create the videos, save the videos, and schedule the entire month’s videos using something like Blotato.
I like your state map and that’s exactly what I’m looking to create. I’ve found a couple n8n workflow templates, but they haven’t been updated in at least 3 months and I just want to make sure they’d still be relevant and I could understand what I’d need to do with them.
Thanks so much for your help!
I have created Video Api Hub integrations | Workflow automation with n8n which helps you generate video though n8n. These are deterministic videos and no LLM is involved. You can work with multiple layers.
Would an avatar be overlay on the video corner
Would an avatar be overlay on the video corner, if yes using heygen works well. And the tool you using should allow download the video without a watermark
Hi @Joe_Simons, welcome to the n8n community.
you can combine templates in this order:
1- Create AI news video content ideas for social media with Perplexity & OpenAI | n8n workflow template
2- Generate AI viral videos with Seedance and upload to TikTok, YouTube & Instagram | n8n workflow template
3- Bulk auto-publish videos to social networks with AI copy and client approval | n8n workflow template
4- Upload to Instagram, TikTok & YouTube from Google Drive | n8n workflow template
Hi Joe. I can help turn this into a safe n8n pipeline, but I would keep the first build narrower than the full monthly publishing system.
A good paid first slice would be $500-$800: competitor URL intake, metadata/script extraction, rewritten script + hooks, a human approval queue, and one review-ready output path. I would not auto-repost competitor assets or enable autopublishing until the source rights, platform rules, and approval gates are clear.
That gives you a working reference workflow first, then the video generation and scheduling modules can be added without turning it into a fragile all-in-one template.
Do you want the first working proof to end in Google Sheets/Drive, Airtable, or directly in a scheduler like Blotato?
Hi Joe — your updated process is specific enough to turn into a practical n8n build, but I would not automate the whole month-to-publish pipeline in one jump.
I’d start with a small paid prototype:
  • Google Sheet with 5-10 competitor video URLs
  • Perplexity/research step that stores title, hook, angle, topic, and why it is an outlier
  • ShadowScript/manual rewrite handoff fields
  • human approval status
  • final asset/link columns for Blotato or the scheduler
  • error/status log so failed items do not disappear
That gives you a working control table first. After the state map is stable, the video generator and scheduler steps can be added one by one.
The main risk is brittle browser automation around tools that do not expose APIs, so I’d separate “reliable n8n workflow” from “manual/API handoff” instead of forcing everything through a hidden browser. Happy to help map or build the first version if you want a contained starting point.
