Need help With HTTP Post Pulling Information
Hey Community!
I am new to n8n and was playing around with setting up a voice AI agent with retell
I am using the http request and running POST in order to trigger a call with my ai agent
However, when I execute this step, it says “The resource you are requesting could not be found”
I have followed the retell AI documentation to the best of my ability and believe that I set it up properly
Here is what I have so far
URL: https://api.retellai.com/v2/create-phone-call
Header:
“headers”:{
“Authorization”: “Bearer [my API key here]”,
“Content-Type”:“application/json”
Please help!
Hey @seansmohr welcome to the community ,
Would you mind embedding your Workflow so I can help you ?
Sorry, how do I go about embedding my workflow here?
Thank you
You can download the n8n at three dots in top right corner, and copy it, after that paste here
Thank you
Here is it
there is nothing wrong with this code, perhaps you forget to set a permission in retell ai?
Hi All!
I was able to figure out the issue and get the call to trigger
Now I am having issues with the webhook lol
I input the webhook URL on the retell side but it never pulls the call summary.
Additionally, I would like for the call summary to be formatted as “Date of call - Quick call summary”, but I do not know how to set that up in N8N. I think the webhook would pull the call summary, feed it to my call summarization powered by OpenAI, and Open AI would have to summarize it based on my parameters?
I am not entirely sure so please help!
Here is the code for the whole tool
The webhook just says, “waiting for you to call test URL”
try to activate the workflow > do something with retell > see the executions tab, maybe it’ll help
have you set up a trigger for the web hook ? … this might help Webhook Overview - Retell AI
I’m having the same problems - how did you fix the http request node? I can’t figure out how to get the call to start
