Hi guys,
I have made a workflow where i make calls via retell api through n8n using a n8n form to be filled by the user.
There is another webhook workflow which takes the call data and records it.
Its working fine when i am using either a test call or making a call manually via Retell.
But when i use n8n to make api call to retell to make call, the call data is not sent to my other webhook and its just not receiving the data.
I have tried a lot of things, please help!
Below are the images of the workflows
Dear @Ansh_Sharma.
Instead of webhook why don’t you try
This way in the first workflow you can use this.
And in the second workflow start it by
This way, instead of relaying on webhook, your one workflow, can directly send information to other workflow.
Happy to help.
(If this help, then please mark it as solution, as this will help other in the community too.)
Greetings @kuldip_parmar Sir,
I used what you said, i put the execute sub workflow after my 1st one.
It sends the info to the 2nd workflow.
The problem is that it send “call registered” info whereas i need call analyzed info.
Have a look!
Dear @Ansh_Sharma, can you please share your both workflow here, I will check it out and develop the workflow you are looking forward to.
Please share your workflow here in
@kuldip_parmar
Please find them below-
Workflow 1 -
Workflow 2 -
Dear @Ansh_Sharma , Everything is looking good. As it’s working inside mine workflow.
Can you please check inside Retell, as may be that where the problem as.
May be you have to setup the webhook note inside Retell again.
Can you please try it and update me as per…
Happy to help…
Thanks a lot @kuldip_parmar
It just came on after i refreshed it like 5 times more.
N8N sure loves to give little heart attacks!
I’m a student in SRCC, India. working on a AI call agent agency with a client onboarded.
I would love to connect with you @kuldip_parmar !
Once again, thanks a lot!
Dear @Ansh_Sharma that a bit funny too. It happen with n8n sometime…
So are you from Delhi right !.
I would love to connect with you. Let’s connect on LinkedIn. Here is my LinkedIn link.
LinkedIn
Happy to help you once again…
