Having a workflow with a Notion Trigger results in DNS EAI_AGAIN errors when automated, but running the workflows manually works fine, same getting test data from notion.
Networking seems fine since I can use HTTP nodes to download webs
"message": "getaddrinfo EAI_AGAIN api.notion.com",
"name": "Error",
"stack": "Error: getaddrinfo EAI_AGAIN api.notion.com\n at Function.AxiosError.from (/usr/local/lib/node_modules/n8n/node_modules/axios/lib/core/AxiosError.js:92:14)\n at ClientRequest.handleRequestError (/usr/local/lib/node_modules/n8n/node_modules/axios/lib/adapters/http.js:620:25)\n at ClientRequest.emit (node:events:524:28)\n at emitErrorEvent (node:_http_client:101:11)\n at TLSSocket.socketErrorListener (node:_http_client:504:5)\n at TLSSocket.emit (node:events:524:28)\n at emitErrorNT (node:internal/streams/destroy:169:8)\n at emitErrorCloseNT (node:internal/streams/destroy:128:3)\n at processTicksAndRejections (node:internal/process/task_queues:82:21)\n at Axios.request (/usr/local/lib/node_modules/n8n/node_modules/axios/lib/core/Axios.js:45:41)\n at processTicksAndRejections (node:internal/process/task_queues:95:5)\n at invokeAxios (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/request-helper-functions.js:173:16)\n at proxyRequestToAxios (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/request-helper-functions.js:513:26)\n at PollContext.requestWithAuthentication (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/request-helper-functions.js:974:16)\n at PollContext.requestWithAuthentication (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/request-helper-functions.js:1147:20)\n at PollContext.notionApiRequest (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Notion/shared/GenericFunctions.js:99:14)\n at PollContext.poll (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Notion/NotionTrigger.node.js:200:29)\n at TriggersAndPollers.runPoll (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/triggers-and-pollers.js:59:16)\n at executeTrigger (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/active-workflows.js:78:38)",
"code": "EAI_AGAIN"
The workflow is just a Notion Trigger with “PageAddedToDatabase”.
- n8n version: 1.91.3
- Database (default: SQLite): PSQL 16
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Running n8n via (Docker, npm, n8n cloud, desktop app): docker
- Operating system: debian
