Romgal
February 25, 2025, 5:02pm
1
Hello,
I am just trying to take a famous template and use it with my space. I create everything, all the connections, but it is not working with notion.
Even If I tried different way, different space, different integration. It’s still the same.
I don’t understand why, and I am suppose that maybe its come from directly from the app integration ?
Because even the link we need to copy/paste is not the same format we get on notion than the one we need to past on N8N…
Could you help me please ?
**n8n version: last
**Database (default: SQLite): don’t know
**n8n EXECUTIONS_PROCESS setting (default: own, main): don’t know
**Running n8n via (Docker, npm, n8n cloud, desktop app): cloud app
**Operating system: Mac OS google chrome
n8n
2
n8n version:
Operating system:
Have you added the connection in Notion:
After you create the integration in Notion (I’m assuming you’ve done it as your credential seems to be configured based on the screenshot), you still need to add that as a connection to the page. Only once you add that, you would be able to query the data.
Also make sure your integration has the required permissions:
Hey @Romgal Welcome to community!
Make sure you’ve followed docs:
Notion Credentials
Romgal
February 25, 2025, 6:21pm
6
Thanks to both of you, yes It was definitely that
@Romgal , kindly select the post that solved your issue so the thread can be marked as completed.
system
Closed
March 4, 2025, 6:25pm
8
