Ollama Chat Model node has no way to disable streaming
Describe the feature
Add a Streaming option to the Ollama Chat Model node. Users can then turn streaming off.
Is your feature request related to a problem?
Yes. The node always sends stream: true to Ollama. Users cannot change this.
The behavior matters for some setups:
  • Log files are hard to read when the model writes in many small chunks.
  • Some proxies buffer a streamed response badly.
  • Users want one complete JSON response for downstream parsing.
Describe the solution you would like
Add a boolean Streaming option to the Ollama Chat Model node. It defaults to true. Existing workflows keep the current behavior.
When the option is off, the node sends stream: false to the Ollama chat endpoint. The response then arrives as one complete payload.
Technical note
The LangChain client version used by n8n stores a streaming field, but its streaming code path always sends stream: true. So the option needs a small wrapper in the n8n node. Tool calls and thinking output keep working, because the client still builds the final message.
Related
