Hi, I am new to n8n and looking for a solutions with following ability:
I need a customable login web page for different roles.
The user should be able to register themself and I should be able to assign them to role.
Then the user will have some button according to his/her role to click.
Button1: User clik on it an is forced to upload a document (docx, pdf or xls) then the document is goint to trigger a workflow in n8n and will give the result back.
Is there some tools that can to this work?
Could you please recommend a solution?
Thanks
