hey i am trying to get page by adding 1 to the previous page how can i make it work in the workflow fellow(pagination)
- n8n version:
- Database (default: SQLite):
- Operating system:
hello @Arsh_Tyagi
That approach wouldn’t work as the Code node will be executed multiple times and only then the HTTP Node starts to work. You will need to use the Loop node or build-in pagination of the HTTP Request node (that is better and simpler).
@barn4k tried using pagination too but didn’t work instead gave me a json error
Could you show me how to use loop node to do this
Here is the example
Take a note that if the HTTP node output’s more than 1 item at a time, the workflow should be tuned, unless it won’t work.
Thank you so much for this workflow you have sorted all the things
