Please help my Telegram trigger stopped working unexpectedly
Hey everyone, I’m having some trouble with my Telegram Trigger node in n8n. It was working fine earlier, but now it’s not triggering when I send messages to the bot. My workflow is still active, and I haven’t changed any settings. Other nodes are working correctly, but I’m not seeing any triggers. Has anyone else experienced this issue or know what might be causing it? I’m using Docker and ngrok. Any help would be appreciated!
thank you so much, I will try these steps and reply you again, thank you once again
