Jon
November 3, 2024, 9:25pm
2
Hey @Dice_Codes
Welcome to the community
That error would suggest either the host or port is wrong or there is a networking issue.
I would start by checking the host, make sure you are not trying to connect to localhost as an example.
Hi thank you for quick reply
I am using my host Ip and other credentials are correct but somehow it is still not working. please suggest.
let me know if you want to see anything from side to solve this
Jon
November 5, 2024, 2:42am
4
Is the host listening on the port you are using? Does the container have access to the IP as well?
I was installing n8n and postgres with docker i reinstalled everything using
n8n with docker and postgres as a diffrent app now it works
