Some options didn’t show on UI, and i got error when i running it.
ERROR: Could not get parameter "columns.mappingMode"!
Error: Could not get parameter "columns.mappingMode"!
at getNodeParameter (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/NodeExecuteFunctions.js:1295:15)
at Object.getNodeParameter (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/NodeExecuteFunctions.js:1592:24)
at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Postgres/v2/actions/database/insert.operation.js:149:20)
at Object.router (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Postgres/v2/actions/router.js:49:81)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:658:19)
at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:631:53
- n8n version: 1.5.1
- Database (default: SQLite): Postgres
- Running n8n via (Docker, npm, n8n cloud, desktop app): docker
- Operating system: linux
