Problem in node 'Execute workflow'
output error:
The resource you are requesting could not be found
Not Found
I can’t live without n8n anymore, I use it every day and it helps me a lot. Recently I used this template and I’m trying to backup my workflow on GitHub, but I’m getting errors. I am deploying with docker on render and set 3 environment variables.
Can anyone help me out with this. Thanks a lot.
  • n8n version: 1.94.1 (Self Hosted)
Hi, just to be sure. Have you edited the id in the execute workflow to your own id?
Here, you need to edit and reference the workflow you created
btw you can also run a cron with these commands too
n8n export:workflow --all
n8n export:credentials --all
