Problem running workflow - Cannot read properties of undefined (reading 'node')
I’m new to n8n and creating a simple workflow. It starts with a ‘When chat message received’ trigger. I’ve activated the workflow. When I send a message (“hi”) in the n8n chat, the trigger node correctly shows ‘1 item’. However, after a short delay, the workflow fails with the error: ‘Problem running workflow - Cannot read properties of undefined (reading ‘node’)’. The execution log also shows ‘Workflow execution had an error - Cannot read properties of undefined (reading ‘node’)’. What could be causing this error, and how can I debug it?
