Problem running workflow
Does anyone run the self hosted (not Docker) version of n8n that can help me diagnose a problem?
I have updated the software to the newest version, and have this recurring issue where every time I choose to execute any step (even a manual trigger)
I get this error: Problem running workflow Cannot read properties of undefined (reading ‘execute’).
I’ve never been able to get a workflow to work properly, and I am just at a loss as to where to look for a solution.
Thanks in advance for any help
@Vexflux your screenshot doesn’t provide much context other than saying the node isn’t able to pick up data because the previous node is pushing an undefined object through.
So it could be a simple fix to your workflow or try restarting the n8n server. Not sure what the issue might be but that should fix it.
You can try providing more details so we troubleshoot together.
Hope this helps, let me know either way.
Save and refresh your workflow first.
How are you hosting it? Actually hosted or via NPM? Do you have access to the stack trace error?
Hey everyone! :waving_hand:
I just ran into this frustrating error and spent way too much time debugging it, so thought I’d share what I learned to save you all some headaches.
What This Error Actually Means
Basically, N8N is trying to run something that doesn’t exist or isn’t properly set up. It’s like asking someone to execute a task, but that someone isn’t there or doesn’t know what you’re talking about.
Where I’ve Seen This Pop Up
Most common scenarios in my experience:
1. Broken Node Connections
This happened to me yesterday - I had deleted a node but forgot one connection was still trying to reference it. The workflow looked fine visually, but there was a phantom connection causing issues.
Quick fix: Double-check all your node connections, especially if you’ve been moving things around.
2. Function Node Mishaps
I love using Function nodes, but they’re also where I mess up the most. Usually it’s something like:
javascript
// This breaks if the previous node didn't return what I expected
const data = items[0].json.someField.execute();
// Better approach:
if (items && items[0] && items[0].json && items[0].json.someField) {
  const data = items[0].json.someField;
3. Webhook Setup Issues
Had this happen when I was testing webhooks. I’d set up the webhook node but forgot to actually activate the workflow, so the webhook was trying to execute on nothing.
4. Manual vs Automatic Execution
Sometimes workflows work perfectly when you hit “Execute Workflow” manually but fail when triggered automatically. Usually means the trigger isn’t passing data the way you expect.
My Debugging Process (What Actually Works)
Step 1: Start Simple I run the workflow manually first, node by node. Click on each node and check what data it’s actually outputting. You’d be surprised how often the data isn’t what you think it is.
Step 2: Check the Browser Console Open your browser’s developer tools (F12) and look at the console. Often there are more detailed error messages there that N8N’s interface doesn’t show.
Step 3: Simplify the Workflow I temporarily remove complex logic and just try to get basic data flowing. Once that works, I add complexity back piece by piece.
Step 4: Validate Everything In any Function nodes, I add checks like:
javascript
if (!items || items.length === 0) {
  return [{ json: { error: "No input data" } }];
Quick Fixes That Have Saved Me
  1. Save and refresh - Seriously, sometimes N8N just needs a refresh
  2. Restart the workflow - Stop it completely and start again
  3. Check node names - If you’re referencing nodes by name in code, make sure the names match exactly
  4. Look for empty required fields - Some nodes fail silently if required fields are empty
Prevention Tips (Learned the Hard Way)
  • Always test with real data, not just the sample data N8N provides
  • Use descriptive node names - “HTTP Request 1” tells you nothing when debugging
  • Add error handling to Function nodes from the start, not as an afterthought
  • Keep a simple test workflow to validate basic functionality
When All Else Fails
Sometimes I just rebuild the problematic part from scratch. It sounds extreme, but I’ve wasted hours trying to fix something that takes 5 minutes to rebuild properly.
Also, don’t forget to check the N8N community forum and GitHub issues - someone else has probably hit the same problem.
Thanks everyone. I got it working. We restarted the n8n server. Not sure what the cause good be. But it worked :slight_smile:
Thanks
@Vexflux awesome! Glad you were able to get it fixed.
If you ever have questions in the future feel free to reach out, and kindly mark as the solution to help others.
