Problem running workflow Request failed with status code 404
I updated n8n and now i get this useless error when trying to test my workflow:
It worked fine before.
What do I need to do?
@Ethan_Fox hi there! Could you share your workflow and the full error message you’re seeing?
Hi I am having same issue. I am trying to test my work flow and I got this messages Problem running workflow
Request failed with status code 403
I got this from console in browser
POST axios-Mm4CS0gO.js:3
https://xxxx.xxxxx.com/rest/workflows/PjqlwfNdmVwrAo0H/run 403 (Forbidden)
