Problem with merge doesn't identify the seconde node
hey guys I am working with two Qradar node , each one them fetch data from a different api endpoints and i want to merge the data but the problem is that the merge flow gets the data of the first node only and the other one assign its data as undefined .
The WORKFLOW
  • n8n version: 1.27.3
  • Running n8n via Docker:
  • Operating system: ubuntu server
i already imported the infos
hello @Ali_Abdelmalek
Please, share the example output for both nodes.
PS and please, clean the authorization token before sharing it :wink:
That’s why you have to use the Credentials in n8n
I have unlisted this topic and removed the workflow from your post history to prevent the token from leaking. Please edit your post and let me know when I can re-list it.
