Problem with n8n on hostinger vps
I was trying to recover my workflows that got lost when I updated hostinger’s vps n8n, and ended up with a black screen 404 page not found error when I access the address.
The more I asked gpt for help, the more messy it got. Can I just reinstall n8n with default setting from scratch? Hostinger uses docker
Hi are you already follow this tutorial? https://www.hostinger.com/tutorials/how-to-self-host-n8n-with-docker
I ended up finding a solution. Thx
could you share your solution plz? i upgraded n8n and got the 404 page on hostinger . no idea how to solve it . thanks!
Sorry, but I only remember I did everything if I was gonna install from scratch. I used hostinger’s ai agent to help me (kept showing errors, etc, until got it right)
thanks . turns out was permission to create log folder for me. but it still didn’t work out as it does a fresh install and wipe out my workflows
