Problems with telegram node
Hello. I’m trying to write a telegram bot that, when you click on a button in the inline menu, will send certain screenshots from a certain resource. The problem arises with the Telegram trigger, it works for some time, about 10 minutes. After that, this node simply goes into timeout. I use a node from the community, because there is no Telegram node with long polling
link to the node I use in my process:
https://www.npmjs.com/package/n8n-nodes-telegram-polling-v7
Hi @KamaR!
Thanks for reaching out, but unfortunately you’ll have to get in touch with the node creator for more information.
Happy building!
