Hello n8n Support Team,
I am a member of a client n8n Cloud workspace, and I’m facing a consistent issue with the Python Code node timing out.
Issue summary
The Python Code node times out even when running very simple one-line code, for example:
return True -
1 + 1
The JavaScript Code node works fine in the same workflow.
Error message
Task request timed out after 60 seconds
Your Code node task was not matched to a runner within the timeout period. This indicates that the task runner is currently down, or not ready, or at capacity, so it cannot service your task.
If you are repeatedly executing Code nodes with long-running tasks across your instance, please space them apart to give the runner time to catch up. If this does not describe your use case, please open a GitHub issue or reach out to support.
Steps to reproduce
Create a new workflow
Add Manual Trigger
Add Python Code node
Use simple code like
return True -
Execute the workflow
Result: The execution times out after 60 seconds.
Expected behavior
The Python Code node should execute immediately, similar to the JavaScript Code node.
What I’ve tried
Updated the n8n version
Cleared all executions
Tested in a brand-new workflow
Tested with minimal Python code
The issue still persists.
This appears to be related to task runner availability or capacity on n8n Cloud, specifically affecting the Python Code node.
Thank you for your support.
