Hi, just connected to my Reddit account and I’m struggling to figure out how to retrieve my Saved posts.
Is this currently possible?
Thanks
Tony
Thanks
Tony
Hey there,
Looking at the docs saved posts doesn’t appear to be an option with the Reddit node. You might be able to do it with the http request node.
Hi Jon, thanks for the quick response!
I found this on their site and wondering if it might work?
Tony
Hey there,
Yeah that would work, just need to work out how to do the rest of the call (authentication and all that jazz). The option is to take a look at the code for the node, if you are able to use JavaScript or learn it you could probably get a pull request put in for the node.
