Blueli
August 15, 2026, 10:50am
1
This thread say the disable auto save is available from n8n@2.20.0
Hi everyone,
Thanks so much for the continued feedback on this thread. We hear you, and we understand the friction this is causing in your day-to-day work.
Our team is looking into the best way to address this properly. We’re aiming for a solution that keeps the benefits of autosave (no lost work, peace of mind) while letting you freely navigate and explore the canvas without every small interaction creating a new version.
We’ll also be investigating the performance concerns raised here. Aut…
Does anyone know where the option is? I can’t find it in the settings. Or is it still something we need to add as an environment variable manually to make it work?
Thank you
master ← uppinote20:master
opened 05:14AM - 02 Feb 26 UTC
## Summary
Add `N8N_WORKFLOWS_AUTOSAVE_DISABLED` environment variable to allow … disabling automatic workflow saving in the editor.
**When autosave is disabled:**
- A **Save button** appears in the workflow header
- **Ctrl+S** (Cmd+S on Mac) triggers manual save
- Automatic saving is completely disabled
**Use case:** Self-hosted/Docker environments where autosave causes performance issues or users prefer explicit control over saving.
**Usage:**
```bash
N8N_WORKFLOWS_AUTOSAVE_DISABLED=true
## Related Linear tickets, Github issues, and Community forum posts
## Review / Merge checklist
- [x] PR title and summary are descriptive. ([conventions](../blob/master/.github/pull_request_title_conventions.md))
- [ ] [Docs updated](https://github.com/n8n-io/n8n-docs) or follow-up ticket created.
- [x] Tests included.
Thank you
achamm
August 15, 2026, 12:02pm
2
@Blueli First, make sure your instance is on 2.20! It’s not a UI setting, but rather a env var
Source
Hello @Blueli ,
It isn’t a toggle in the n8n settings. The feature is controlled by the `N8N_WORKFLOWS_AUTOSAVE_DISABLED=true` environment variable.
For Docker Compose, add it under the n8n service’s `environment:` section, then recreate the container with `docker compose up -d --force-recreate`. A normal restart won’t apply a newly added environment variable.
You can confirm it reached the container with:
```bash
docker compose exec n8n printenv N8N_WORKFLOWS_AUTOSAVE_DISABLED
If that returns `true` but you still don’t see the Save button, check the running n8n version rather than the image tag in the Compose file.
Blueli
August 15, 2026, 1:43pm
4
Yes thank you for confirming that we will need to add an env var to enable it.
