Scheduler triggers are not executed as expected
I’m facing an issue with a Schedule Trigger in a workflow that is configured to run every 15 minutes from 08:00 to 23:00 IST. However, I’ve observed that some scheduled times are being skipped or missed intermittently.
For example, on 2025-04-09, the trigger skipped expected executions at 08:15, 08:45, and 10:00. Other times fired as expected.
We are using queue mode with ECS autoscaling. I have already ensured:
  • n8n version: 1.72.1
  • **Database :Postgres
  • n8n EXECUTIONS_PROCESS setting : main -queue mode
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Docker on ECS
  • Operating system: Amazon Linux (ECS Fargate)
Hi,
Would you happen to use fargate spot instances?
How are your containers sized (cpu/mem)?
Regards
J.
Each Worker will have 0.5 CPU and 1 GB memory based on no of jobs running
