Send message not working for users number
I’m working with n8n + WhatsApp Cloud API.
When I send a message from my own WhatsApp number, the reply works perfectly.
But when I try sending a message from a different WhatsApp number, the workflow fails with an error while sending the reply (DNS / server offline type error).
Webhook receives the message correctly, but the send message step fails only for other numbers.
I’m currently using:
  • Meta test number
  • Phone Number ID as sender
  • messages[0].from as recipient
Has anyone faced this issue?
Do I need to add all recipient numbers as test users, or is this related to app mode (dev vs live)?
Any guidance would be appreciated. Thanks!
Welcome to the community :tada: @Himanshu_wasnik
See this thread:
Hope this helps!
thank you for your response
