sendDice Method in Telegram Node (for Sending Animated Emojis)
Can we send Animated Emojis in Telegram Node?
Perhaps you can use the message:sendAnimation.
How bro? I’m confused :thinking:
Hey @mcnaveen!
If the Animation File is on the Telegram server you can reference it using its ID. But if it isn’t, you will have to pass a URL. I also took a look at the API and it looks like there needs to be a separate endpoint for sending animated emojis. But I might be wrong. Can you try with the Send Animation operation?
Where can I get the Animation File ID bro?
for example. I need it for “:basketball:”
For this you will have to check the Telegram API.
Hey @harshil1712
Seems this is new. https://core.telegram.org/bots/api#senddice
Is this currently supported in Telegram n8n node?
Have a look here. @RicardoE105
https://api.telegram.org/botTOKEN/sendDice?chat_id=YOURCHATID&emoji=🏀
Currently n8n supports sendMessage Method. But this functionality requires sendDice Method.
Just took a look at the code, and currently the Telegram node doesn’t support this operation. Maybe you can create a feature request for this so that we can add it :slightly_smiling_face:
Done. :heart:
