Can anybody help we with this or has the same problem? ![]()
Since 2.15.0: When executing a workflow manually, my docker compose logs outputs
n8n-1 | Skipping execution data push: unable to resolve user for redaction
n8n-1 | Attempt to read execution was blocked due to insufficient permissions
when my workflow contains e.g. a webhook-node that pushes back data to the browser of my browser.
To Reproduce
Simply run a flow or a part of a flow that has a webhook-trigger for example in the editor and then run it.
If you try to open a node that just ran, it won’t load it’s input and output data, probably due to the errors above.
Expected behavior
Load input and output data as expected.
Debug Info
My docker-compose looks like this. I use custom ports, a custom certificate and a mini dns. Besides that it’s fairly standard and according to he official Docker Compose | n8n Docs
services:
traefik:
image: "traefik"
restart: always
command:
- "--api=true"
- "--api.insecure=true"
- "--providers.docker=true"
- "--providers.docker.exposedbydefault=false"
- "--entrypoints.web.address=:60080"
- "--entrypoints.web.http.redirections.entryPoint.to=websecure"
- "--entrypoints.web.http.redirections.entrypoint.scheme=https"
- "--entrypoints.websecure.address=:60443"
#- "--certificatesresolvers.mytlschallenge.acme.tlschallenge=true"
#- "--certificatesresolvers.mytlschallenge.acme.email=${SSL_EMAIL}"
#- "--certificatesresolvers.mytlschallenge.acme.storage=/letsencrypt/acme.json"
- "--providers.file.directory=/etc/traefik/dynamic"
ports:
- "60080:60080"
- "60443:60443"
volumes:
- ${DATA_FOLDER}/letsencrypt:/letsencrypt
- /var/run/docker.sock:/var/run/docker.sock:ro
- ${DATA_FOLDER}/cert:/cert
- ${DATA_FOLDER}/cert/certs-traefik.yml:/etc/traefik/dynamic/certs-traefik.yml
n8n:
image: n8nio/n8n
restart: always
ports:
- "127.0.0.1:5678:5678"
labels:
- traefik.enable=true
- traefik.http.routers.n8n.rule=Host(`${SUBDOMAIN}.${DOMAIN_NAME}`)
- traefik.http.routers.n8n.tls=true
- traefik.http.routers.n8n.entrypoints=web,websecure
#- traefik.http.routers.n8n.tls.certresolver=mytlschallenge
- traefik.http.middlewares.n8n.headers.SSLRedirect=true
- traefik.http.middlewares.n8n.headers.STSSeconds=315360000
- traefik.http.middlewares.n8n.headers.browserXSSFilter=true
- traefik.http.middlewares.n8n.headers.contentTypeNosniff=true
- traefik.http.middlewares.n8n.headers.forceSTSHeader=true
- traefik.http.middlewares.n8n.headers.SSLHost=${DOMAIN_NAME}
- traefik.http.middlewares.n8n.headers.STSIncludeSubdomains=true
- traefik.http.middlewares.n8n.headers.STSPreload=true
- traefik.http.routers.n8n.middlewares=n8n@docker
- "traefik.http.middlewares.n8n.headers.customResponseHeaders.Access-Control-Allow-Origin=*"
environment:
- N8N_HOST=${SUBDOMAIN}.${DOMAIN_NAME}
- N8N_PORT=5678
- N8N_PROTOCOL=https
- NODE_ENV=production
- WEBHOOK_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}:60443/
- GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
- N8N_DIAGNOSTICS_ENABLED=false
- N8N_VERSION_NOTIFICATIONS_ENABLED=false
- EXECUTIONS_DATA_SAVE_ON_ERROR=all
- EXECUTIONS_DATA_SAVE_ON_SUCCESS=none
- EXECUTIONS_DATA_SAVE_ON_PROGRESS=true
- EXECUTIONS_DATA_SAVE_MANUAL_EXECUTIONS=false
- EXECUTIONS_DATA_PRUNE=true
- EXECUTIONS_DATA_MAX_AGE=336
- DB_SQLITE_VACUUM_ON_STARTUP=true
- N8N_INSECURE_DISABLE_WEBHOOK_IFRAME_SANDBOX=true
- N8N_RESTRICT_FILE_ACCESS_TO=/files
- DB_SQLITE_POOL_SIZE=2
- N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
volumes:
- ${DATA_FOLDER}/.n8n:/home/node/.n8n
- /local-files:/files
Debug info
core
- n8nVersion: 2.15.0
- docker (self-hosted)
client
- userAgent: mozilla/5.0 (windows nt 10.0; win64; x64) applewebkit/537.36 (khtml, like gecko) chrome/147.0.0.0 safari/537.36
Operating System
Windows
n8n Version
2.15.0
Node.js Version
24.13.1
Database
SQLite (default)
Execution mode
main (default)
Hosting
self hosted
