[SOLVED] Problem with node n8n workflow to Github
Hello,
I have a workflow that used to work for quite some time, but since an update it no longer works.
It stops on an n8n node that retrieves the list of workflows, and I get a 404 error.
I’ve already tried regenerating the API key, but that didn’t solve the issue.
Can someone help me with this?
Thanks :slight_smile:
Hi @Lyoto , welcome to the :n8n: community!
I think you just need to delete the API and create a new one, since the API has been updated with “scopes” and other things
Also, make sure the connection is successfully established:
I believe this will fix your issue.
:point_right: If this solves your problem, feel free to mark the reply as the solution :white_check_mark: it’ll help others with same issue, and it also helps me on the leaderboard :folded_hands:t2:
Thank you for your help, my base URL was missing /api/v1.
My issue is now resolved.
yeah, tht could happen, it also happens to me as well, xd
if your question is solved, and you solved it by your own, you can mark your own answer as the solution btw, thts usually how you let people know that your question is solved
Glad the issue is fixed @Lyoto :tada:,
Kindly mark my reply as the solution, thanks and have a nice day!
