Specify Input Schema
I’m using n8n version 1.77.3 I don’t see the “Specify Input Schema” open when setting up a work flow tool. Been at it for over and hour and can’t figure out where that open is or how to enable it.
  • n8n version: 1.773
  • **Database (default: SQLite):**PostGres
  • Running n8n via (Docker):
  • Operating system: Mac OS
I’m in the same boat. I am working on a pretty simple agent. I’m calling a sub-agent for posting to a WordPress blog. When I add the agent call node I don’t see the “Specify Input Schema” option? Without it, all I am passing is a query and no formatting, so it’s pretty much useless. Do I need to set up the schema in the trigger node? Am I missing something?
I’m using the cloud service, so it should be the latest version.
Newbie here, so kid gloves, guys. This is a great tool. I’m learning, but I just thought I would ask the community.
Hey @GentiumAI and @Siafu,
thanks so much for the question. I’ve responded to the same issue in another thread: Why input schema from "Call n8n Workflow Tool" was removed on 1.74.3? - #10 by Niklas_Hatje
Does that help? It might be confusing right now, since we seem to have many youtube tutorials out there right now with the old paradigm, but I hope my answer here makes sense. If not, please let me know how I can help you further.
