Split Items - ID extract
Hi,
I am newbie and haven’t found an helpful answer yet in the forum.
From my start trigger I receive this JSON and I want to split out the items and execute the workflow for each ID contained in the body, but I am just not getting how to split that. The split node just returns the same as the input.
"headers":
"host":
"xxx",
"x-real-ip":
"xxxx",
"x-forwarded-for":
"xxx",
"x-forwarded-proto":
"https",
"x-forwarded-port":
"443",
"connection":
"close",
"content-length":
"228",
"accept":
"application/json, text/plain, */*",
"content-type":
"application/x-www-form-urlencoded",
"authorization":
"xxxx",
"user-agent":
"axios/1.7.2",
"accept-encoding":
"gzip, compress, deflate, br"
"params":
"query":
"body":
"[ { "ID": "["56fcda38-d904-43b6-9a80-6026902b77c7","f15b5c33-cf13-4c66-9df8-8b9d81f6d0ea","5d07e183-e63e-4dd7-9dfc-6a98cffef0ac","68a79d37-3fce-4843-b226-0a9463f21ac1","35e1c9f9-7366-4b53-8446-8f465c941aee"]" } ]":
"webhookUrl":
"https://xxx/webhook-test/xxx",
"executionMode":
"test"
Maybe it is an issue how the “body” is formatted?
{"[\n    {\n        \"ID\": \"[\"56fcda38-d904-43b6-9a80-6026902b77c7\",\"f15b5c33-cf13-4c66-9df8-8b9d81f6d0ea\",\"5d07e183-e63e-4dd7-9dfc-6a98cffef0ac\",\"68a79d37-3fce-4843-b226-0a9463f21ac1\",\"35e1c9f9-7366-4b53-8446-8f465c941aee\"]\"\n    }\n]":""}
I am using the on premise version: 1.41.0
Hi @marcodworschak
Thanks for posting here and welcome to the community! :partying_face:
Yes the body output looks indeed a bit strange. You would need the format to be like this in order for the Split Out node to work properly:
        "ID": [
Something like this:
I was expecting that, can I achieve that somehow with n8n ?
yeah although it’s a bit ugly but you could use the code node to transform the body content into a string first and then use some regex to replace these escape characters and extra quotes
Thank you,
solved it with.
// Get the input data
const inputData = $input.all();
// Extract the body content
const bodyContent = inputData[0].json.body;
// Extract the key (which is a JSON string) and clean it up
const key = Object.keys(bodyContent)[0];
// Remove any extra characters and parse it properly
const cleanedKey = key.replace(/\\n/g, '').replace(/\\/g, '').replace(/\"\[/g, '[').replace(/\]\"/g, ']');
// Parse the cleaned JSON string
const parsedBody = JSON.parse(cleanedKey);
// Format the output
const output = parsedBody.map(item => ({
// Return the formatted data
return output;
