Hello all! I am a beginnner working with n8n recently. I have become stuck on a problem and I am not sure what the solution is. I have an HTTP Request node that is Getting an array of data which contains multiple objects. I want to try and separate each object out from the array but I’m struggling doing that.
This is the output from the HTTP Request node.
I tried using the Split Out Node and splitting out “data” but it is producing a weird result. It says it is producing two items but I can only see one.
If I examine the JSON output, it looks like there are two items there but I don’t know how to get to both.
JSON Details
“source”: “Playground”,
“id”: “b61713fc-944c-4e2a-8eb3-f4c516543f5b”,
“form_submission”: null,
“messages”: [
“role”: “assistant”,
“content”: “Hi! What can I help you with?”,
“createdAt”: “2025-11-09T05:20:27.431Z”
“id”: “34406bf0-c5d6-4068-8206-247afcc690d5”,
“role”: “user”,
“content”: “Test2”,
“id”: “517d0bb1-0148-4ed0-9ab2-29b7bb1d0773”,
“type”: “text”,
“score”: 0.466796875,
“source”: “llm”,
“stepId”: “29494af2-02fe-4a39-96d9-3b49a42fe3bc”,
“content”: “Hello! How can I assist you with your printer today?”,
“createdAt”: “2025-11-09T05:20:30.243Z”,
“matchedSources”:
“min_score”: 0.466796875,
“created_at”: “2025-11-09T05:20:30.773611+00:00”,
“last_message_at”: “2025-11-09T05:20:30.773611+00:00”,
“country”: “United States”
“id”: “50d50dbf-d61c-47f8-9099-0a72eda1b87b”,
“messages”: [
“createdAt”: “2025-11-09T04:57:36.212Z”
“id”: “86561ac7-091a-47a6-a218-d851a66d1f05”,
“role”: “user”,
“content”: “Test”,
“id”: “6095231d-c98d-416c-bf16-f3b5d2577a18”,
“type”: “text”,
“score”: 0.53515625,
“source”: “llm”,
“stepId”: “ec6ff4e3-b626-48e6-b330-a2e11cd2c2dc”,
“createdAt”: “2025-11-09T04:57:38.358Z”,
“matchedSources”:
“min_score”: 0.53515625,
“created_at”: “2025-11-09T04:57:38.917591+00:00”,
“last_message_at”: “2025-11-09T04:57:38.917591+00:00”,
When looking at the next node, which I currently have set as a filter node, I can only see one item as output even though it says there are two.
Can someone confirm that I am on the right track here or should I be trying to do something different? What am I doing wrong?
Thank you!
