Switch1 node output
In Switch1 node, I’m not sure why both output would be sent. Happens in both Test and Production.
Switch node works fine; only 1 output would be sent.
What is there to check?
  • n8n version: 1.103.1
Hey @charleslcso hope all is well.
Both outputs are set because you changed the settings of the node to Always Output Data. This setting is to make the node to produce empty result for when there is no result, so that the workflow can continue even if there is no output by the node.
Change it back and your problem will likely go away.
