Postman window screenshot : Awesome Screenshot
Easy workflow: webhook GET node connected to Set node. Test URL works fine in Postman but production do nothing.
Here is my DB
/home/node # sqlite3 /home/node/.n8n/database.sqlite
SQLite version 3.48.0 2025-01-14 11:05:00
Enter “.help” for usage hints.
sqlite> .tables
annotation_tag_entity migrations
auth_identity processed_data
auth_provider_sync_history project
credentials_entity project_relation
event_destinations settings
execution_annotation_tags shared_credentials
execution_annotations shared_workflow
execution_data tag_entity
execution_entity test_case_execution
execution_metadata test_run
folder user
folder_tag user_api_keys
insights_by_period variables
insights_metadata webhook_entity
insights_raw workflow_entity
installed_nodes workflow_history
installed_packages workflow_statistics
invalid_auth_token workflows_tags
sqlite> SELECT * FROM webhook_entity; ### ← Workflow was active
4r360oJti7AVMr9k|ea299d62-164f-482d-ad88-c30f3c535e0c|GET|Webhook|| ## There is hook
sqlite> SELECT * FROM webhook_entity; ### ← Set Workflow isnactive via UI, made SELECT, table is empty
sqlite> SELECT * FROM webhook_entity; ### set workflow active again
sqlite>
So webhook entity appears and disappears as in should
Traefik log
2025-06-04T10:32:48Z DBG traefik/traefik/v3/pkg/server/service/loadbalancer/wrr/wrr.go:173 > Service selected by WRR: http://172.18.0.2:5678
2025-06-04T10:40:36Z DBG traefik/traefik/v3/pkg/server/service/loadbalancer/wrr/wrr.go:173 > Service selected by WRR: http://172.18.0.2:5678
2025-06-04T10:40:44Z DBG traefik/traefik/v3/pkg/server/service/loadbalancer/wrr/wrr.go:173 > Service selected by WRR: http://172.18.0.2:5678
It recieves request from Postman and pass it to n8n - OK
But n8n DO NOTHING! )))
n8N log
2025-06-04T10:30:30.354Z [Rudder] debug: no existing flush timer, creating new one
2025-06-04T10:30:40.355Z [Rudder] debug: in flush
2025-06-04T10:30:40.355Z [Rudder] debug: cancelling existing flushTimer…
2025-06-04T10:30:45.504Z [Rudder] debug: no existing flush timer, creating new one
2025-06-04T10:30:45.510Z | debug | Added webhooks for workflow “Easy webhook” (ID 4r360oJti7AVMr9k) {“scopes”:[“workflow-activation”],“workflowId”:“4r360oJti7AVMr9k”,“file”:“active-workflow-manager.js”,“function”:“addWebhooks”}
2025-06-04T10:30:47.456Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:30:47.456Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:30:55.507Z [Rudder] debug: in flush
2025-06-04T10:30:55.507Z [Rudder] debug: cancelling existing flushTimer…
2025-06-04T10:31:15.813Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:31:17.460Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:31:17.460Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:31:47.462Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:31:47.462Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:32:15.817Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:32:17.468Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:32:17.469Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:32:47.472Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:32:47.473Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:33:15.822Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:33:17.475Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:33:17.476Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:33:17.491Z | debug | Found no executions to hard-delete {“scopes”:[“pruning”],“file”:“executions-pruning.service.js”,“function”:“hardDelete”}
2025-06-04T10:33:17.491Z | debug | Hard-deletion in next 15 minutes {“scopes”:[“pruning”],“file”:“executions-pruning.service.js”,“function”:“scheduleNextHardDeletion”}
2025-06-04T10:33:47.478Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:33:47.479Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:34:15.824Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:34:17.481Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:34:17.481Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:34:47.483Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:34:47.484Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:35:15.824Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:35:17.485Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:35:17.486Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:35:47.488Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:35:47.489Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:36:15.826Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:36:17.490Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:36:17.491Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:36:47.492Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:36:47.493Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:37:15.827Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:37:17.495Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:37:17.495Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:37:47.497Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:37:47.497Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:38:15.827Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:38:17.498Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:38:17.499Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:38:47.500Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:38:47.501Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:39:15.832Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:39:17.502Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:39:17.502Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:39:47.503Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:39:47.504Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:40:15.833Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:40:17.505Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:40:17.505Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:40:47.506Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:40:47.506Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:41:15.841Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:41:17.507Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:41:17.507Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:41:47.509Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:41:47.509Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:42:15.841Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:42:17.509Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:42:17.509Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:42:47.509Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:42:47.510Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:43:15.841Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:43:17.511Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:43:17.511Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:43:47.512Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:43:47.517Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:44:15.841Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:44:17.513Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:44:17.514Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:44:47.516Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:44:47.516Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:45:15.842Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:45:17.518Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:45:17.518Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:45:47.519Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:45:47.520Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
2025-06-04T10:46:15.843Z | debug | Querying database for waiting executions {“scopes”:[“waiting-executions”],“file”:“wait-tracker.js”,“function”:“getWaitingExecutions”}
2025-06-04T10:46:17.522Z | debug | Stopped flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“stopFlushingTimer”}
2025-06-04T10:46:17.522Z | debug | Started flushing timer {“scopes”:[“insights”],“file”:“insights-collection.service.js”,“function”:“startFlushingTimer”}
“nodes”: [
“parameters”: {
“path”: “ea299d62-164f-482d-ad88-c30f3c535e0c”,
“options”: {}
“type”: “n8n-nodes-base.webhook”,
“typeVersion”: 2,
“position”: [
-120,
0
“id”: “e3633ee9-c564-488d-b581-2f118e88edab”,
“name”: “Webhook”,
“webhookId”: “ea299d62-164f-482d-ad88-c30f3c535e0c”
“parameters”: {
“assignments”: {
“assignments”: [
“id”: “58fca696-dc60-4895-b16c-f1081b7347fb”,
“name”: “body”,
“value”: “={{ $json.body }}”,
“type”: “string”
“options”: {}
“type”: “n8n-nodes-base.set”,
“typeVersion”: 3.4,
“position”: [
220,
0
“id”: “bf4ede03-e742-4b2f-8e3a-b378f1d6478d”,
“name”: “Edit Fields”
“connections”: {
“Webhook”: {
“main”: [
“node”: “Edit Fields”,
“type”: “main”,
“index”: 0
“pinData”: {},
“meta”: {
“instanceId”: “742c899cd25fa91792ae2856cef673804f2bbd17a8c907d22153cda8d1a7cae5”
## Share the output returned by the last node
<!-- If you need help with data transformations, please also share your expected output. -->
- **n8n version:** 1.95.3
- **Database (default: SQLite):**
- **n8n EXECUTIONS_PROCESS setting (default: own, main):** not set in docker-compose.yml
- **Running n8n via (Docker, npm, n8n cloud, desktop app):** Docker
- **Operating system:** Ubuntu 22.04.5 LTS
----------------- docker-compose.YML ---------------------------
services:
traefik:
image: "traefik"
restart: always
command:
- "--api=true"
- "--api.insecure=true"
- "--providers.docker=true"
- "--providers.docker.exposedbydefault=false"
- "--entrypoints.web.address=:80"
- "--entrypoints.web.http.redirections.entryPoint.to=websecure"
- "--entrypoints.web.http.redirections.entrypoint.scheme=https"
- "--entrypoints.websecure.address=:443"
- "--certificatesresolvers.mytlschallenge.acme.tlschallenge=true"
- "--certificatesresolvers.mytlschallenge.acme.email=${SSL_EMAIL}"
- "--certificatesresolvers.mytlschallenge.acme.storage=/letsencrypt/acme.json"
ports:
- "80:80"
- "443:443"
volumes:
- traefik_data:/letsencrypt
- /var/run/docker.sock:/var/run/docker.sock:ro
n8n:
image: docker.n8n.io/n8nio/n8n
restart: always
ports:
- "127.0.0.1:5678:5678"
labels:
- traefik.enable=true
- traefik.http.routers.n8n.rule=Host(`${SUBDOMAIN}.${DOMAIN_NAME}`)
- traefik.http.routers.n8n.tls=true
- traefik.http.routers.n8n.entrypoints=web,websecure
- traefik.http.routers.n8n.tls.certresolver=mytlschallenge
- traefik.http.middlewares.n8n.headers.SSLRedirect=true
- traefik.http.middlewares.n8n.headers.STSSeconds=315360000
- traefik.http.middlewares.n8n.headers.browserXSSFilter=true
- traefik.http.middlewares.n8n.headers.contentTypeNosniff=true
- traefik.http.middlewares.n8n.headers.forceSTSHeader=true
- traefik.http.middlewares.n8n.headers.SSLHost=${DOMAIN_NAME}
- traefik.http.middlewares.n8n.headers.STSIncludeSubdomains=true
- traefik.http.middlewares.n8n.headers.STSPreload=true
- traefik.http.routers.n8n.middlewares=n8n@docker
environment:
- N8N_HOST=${SUBDOMAIN}.${DOMAIN_NAME}
- N8N_PORT=5678
- N8N_PROTOCOL=https
- NODE_ENV=production
- WEBHOOK_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
- WEBHOOK_TUNNEL_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
- GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
- N8N_DISABLE_PRODUCTION_MAIN_PROCESS=true
- EXTERNAL_MODULES_ALLOW_LIST=*
#new
- NODE_FUNCTION_ALLOW_BUILTIN=*
- NODE_FUNCTION_ALLOW_EXTERNAL=*
# end new
# - NODE_PATH=/usr/local/lib/node_modules
- NODE_PATH=/data/node_modules
volumes:
- n8n_data:/home/node/.n8n
- ./local-files:/files
# - /n8n-packages/node_modules:/data/node_modules
volumes:
n8n_data:
traefik_data:
