I often have the error message:
“Problem activating workflow
Please resolve outstanding issues before you activate it”"
However, no node is displaying an error in my Workflow:
What is likely the root of the problem and how could I fix it?
Thanks
Thanks
Hi @Lesterpaintstheworld, I feel you. This message drives me nuts whenever I see it ![]()
I suspect the problem will be with one of the trigger nodes. Are the credentials you’re using on your RabbitMQ trigger nodes working as they should? Are you able to enable this workflow if you remove everything but the RabbitMQ trigger node (of course only for testing purposes, so make sure to keep a copy/backup)?
